#3 missfire.
Scarylarry
sarasota fla
Just did all the regular coil,plugs and injector, check for coil pulse and injector pulse. still dead. Just did a compression test.....................This white boy just ain't got that kind of money......DAMN.
NCRaineman
NC
2019 1500 Classic
Welcome to owning a Hemi. How many miles did you get? It doesn't happen to everybody but it does happen.
Dodge 1500 4X4
Rochester, NY
Pull the valve cover on drivers' side and look for rocker arm movement on #3.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
i have been thinking about all the #3 misfires
Is the #3 valves/cylinder, camshaft, etc
One of the cylinders that cuts out, when MDS kicks in & out ?
The other part of the question,
do the HEMI engines that don't have MDS, have the same issue with the #3 ?
NCRaineman
NC
2019 1500 Classic
Don't believe it is related to MDS at all, as the roller part of the lifter is what's failing and MDS doesn't effect that part.
GTyankee
3.0 ecodiesel
That would leave me to believe that the MDS Camshaft is to darn SOFT, unless the non MDS engine are equally affected
RamRod37
2014 Ram 2500 HD 5.7 Hemi
Georgetown TN
and no MDS is cylinders 1,4,6,7
The manual transmission 5.7 and 6.4 Challengers are non-mds,and they still eat cams and lifters.
