325/60-20 How much needed to fit
WilliamS
Tampa FL
I keep looking at 35's but hate that they are not actually 35's. So on stock 20x9's and the bilsteins maxed out do I have any chance of them fitting without major surgery? I do not mind cutting up some plastic or spacers but I really wonder what it will take.
I have no want for aftermarket wheels as the stockers look just fine, just want to fill up some wheel well.
Fanta1500
Albany NY
I have bils maxed out with 305/55/20 -18 offset and slightly rub. 35s fit with stock wheels but might have to run spacers so tires don't rub on uca
R.L.K.
Bristol , Tn.
If I were you Sir , I'd have a set of bora hub/ wheel centric 10 mm spacers on hand .....but you should not need them with 325/60 tire on stock wheels .
Do report back , as this is how we learn here !
Sent from my SM-G900V using Tapatalk
W
WilliamS
Tampa FL
Would 10mm be enough? I know plenty of guys that run a 35x12.5 on the stock 20's need that same 10mm. These tires are a solid 13 inches wide. I know they will fit and be all bulgy on the stock wheels, which I like the look but 10mm might not be enough?
R.L.K.
Bristol , Tn.
Hmm , good point .
I'd go here :
http://www.ramforum.com/showthread.php?p=1087055
Read the section on tire selection and offset , it's a fantastic guide by Brandonjanson imo .
Hope this helps !
R.L.K.
Bristol , Tn.
Looks like a 1" spacer to be safe , with that said you may consider a 1.75" spacer to keep from trimming the oem lugs .
Or go with a -12mm offset wheel of your choice ? A - 12mm would put you 31mm further out than you are now about an inch & a quarter .
BiGMERF
2017 SLT 4x4
v6
I have 1.75 boras. Good choice. But it may give him a look he using ready for. Forget it, just saw its stock wheels.... high offset
R.L.K.
Bristol , Tn.
Yep I believe his wheels are a +19 mm now , which is about 3/4 " IN
6.7CumminsDrvr
The Dude abides………
Georgia
You could also look into 295/65/20's
They spec out to about 35.4" and right at 12" wide on a factory 20x9
stimpy433
IOWA
I have 295/60-20's on OEM Chrome Clads with my Bilsteins set @ 2.8". That's about as big as you can get with any rubbing.
Csanders1992
I'm running 35x12.50 on stock big horn chrome clads with no rubbing anywhere
Ratket
Arizona-
Remember not all tires measure out to what that tire size says it should be- best to look at the manufacture you want and check their size chart- a lot of 35"s don't measure out to 35 and the same can be said for the width as well.
No way he's running that on a 1500 stock.
W
WilliamS
Tampa FL
Almost none of the 35x12.5s ive seen actually measure out to a 35 inch. The tires Im looking at the G2's as thats what i have now are 35.5 inches tall.
Arturo Rojas
