33s or 35s
newrammer
5.9 v8 magnum
I know there's close to 1000 threads on what tire goes with what gear, but I couldn't find a whole lot on 2500s. With dana 60s and what I believe to be 3.55s (the glove box says 3.55 but yet I do 1900 rpm at 70mph) , would 33s or 35s be okay with my somewhat beefier transmission?
newrammer
newrammer
5.9 v8 magnum
Huh, not sure why but I thought i read somewhere that it was more tough than the 1500s but less tough than the one put in cummins'
Merc225hp
NA
truck
gas
If you have an auto then same rule applies as it's the same as the 1500 trucks 46re, if it's a stick truck no big deal as it will have the nv4500.
newrammer
newrammer
5.9 v8 magnum
Ah, there ya go then
Merc225hp
NA
truck
gas
Find a set of 4.10's new or used.
newrammer
newrammer
5.9 v8 magnum
As a kid still paying for college that's a little out of my budget, think I'll just do a two inch lift (if they make them that low) with 33s . I don't need too much clearance, just enough for late night trail rides.
BlackMagnum2000
Locust Grove, GA
5.9 Magnum
For the record, which I know it's not a great idea and I wouldn't suggest it, I run 37s with 3.55s with a stock 46RE. Haven't had problems... Yet.....
newrammer
newrammer
5.9 v8 magnum
Don't get my hopes up haha
BBartow
New Port Richey, Florida
5.9L Magnum
You don't need a 2" lift. You'll have plenty of room for 33s stock.
Merc225hp
NA
truck
gas
You could always try the trade/swap thing.
"For swap or trade Dodge 2500 front a rear Dana 60's with 3.55 ratio for Dana 60's with 4.10 ratio".
Never hurts to try.
newrammer
newrammer
5.9 v8 magnum
I could always do that if I could find some one locally. And I really like having the space between tire and truck, hence the 2 inch lift
Johnn123
Ontario
2" lift id get a 2" coil spacer and 2" AAL.
newrammer
newrammer
5.9 v8 magnum
Yep that's what I was thinking, with that size it shouldn't run too much into my wallet
ADudeOnSkis
Truckee, CA
318/5.2 Magnum
Look into what merc said and try and find a set of Dana 60s with 4.10s. Should be a super easy swap...
newrammer
newrammer
5.9 v8 magnum
If I can find one locally i'm going to jump right on it. I just live in god's waiting room where the average age is 72 (literally) and they all drive a smart car, but I will definitely search every now and then.
gville35
