33X12.50R20 Tires Question
Shakenbake76
FT.Lauderdale
HEMI 5.7L
Will these wheels and tires fit on a stock 2016 Ram 1500 SLT 2WD suspension?? No level kit or lift
Thanks
HemiPower36
CA
2014 Ram 1500 Laramie 4x4 3.92 8-speed
Need a level bra. Bilstein 5100 shocks are pretty cheap on Amazon.
I run 35x12.5r20's and the level in needed
N1ck
Regina Sk
No level needed, just a 1/4” wheel spacer if you’re running Factory 20’s.
S
Shakenbake76
FT.Lauderdale
HEMI 5.7L
The wheel is Laramie Edition factory wheel does that make a difference?
N1ck
Regina Sk
The factory 20’s, regardless of trim level generally need a 1/4” wheel spacer to fit the width of the 12.50” tire, some guys can pull it off without the wheel spacer but most need it.
S
Shakenbake76
FT.Lauderdale
HEMI 5.7L
Thanks
S
Shakenbake76
FT.Lauderdale
HEMI 5.7L
Finally put them on, put on 1/4”spacers the wheel and tires fit perfectly no rubbing.
