3500 vs 4500 specs
kevin1
Maryland
v10
Hello all,
I'm hoping to order a new truck next week. I'm stuck between a cab chassis 3500 or 4500. Can't find much info on how they differ other than payload and towing.
I'd be getting a Gasser. Wondering how the suspensions compare and ride as well as the brakes.
I'm planning on putting a CM AL Sk (https://cmtruckbeds.com/truck-beds/al-sk-truck-bed/) flat bed on it to carry a truck camper. This camper is only about 3k wet but in the future I may get a heavier camper, 5K or 6K could be possible. Currently on a 1997 2500.
Dealers are no help, at least the sales people. Guess I should pop into a shop and talk to the techs.
Your thoughts would be appreciated. I think the 3500 would do me fine but wonder if the 4500 would be a better choice. I'd be getting a Laramie.
Oddly enough the choices of options on a C&C vs pickup are not the same. Annoying.
20160722_123309.jpgper
audiophile
5.7L
Really depends on your end goal. With the 4500 you gain about 2500 GVW, 1900 payload and about 2400 in max towing. Suspension is a 5 link on the 4500 vs a 3 link on the 3500 (front) and leafs on the rear. Brakes have 15.35" rotors front and back (4500) and 14.17/14.09 F/R on the 3500. What other info are you needing?
kevin1
kevin1
Maryland
v10
Thanks for the info. I'm sure the 3500 would do fine just didn't know if it made sense to do a 4500. The larger brakes may be worth it and the tires I believe are 19.5 so better for loads. Not sure how the ride would be with a 4500 with what would be a light load for it. Towing isn't a concern. Didn't know how else they differed and if it would make sense to go 4500.
NH RAM
New Hampshire
2019 Tradesman 2500 Snow Chief
The 3500 DRW has the 8HP75 with 4.10 rear and 14,000 GVWR but can be had with the Aisin AS66 and 4.44 gears; the 4500 has the Aisin AS66 with 4.44 or 4.89 rear gearing and 16,500 GVWR. You're correct that the 4500 will have the 19.5 tires.
This link has some comparisons on things such as the cast aluminum vs cast iron track bar brackets in the 3500 and 4500 info.
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
6.4L HEMI
All I can tell you is the 5 link gives a far superior ride, IF you don't need the extra load capacity of the leaf springs. There's a reason they use leaf springs on dump trucks.
Billet Bee
South Dakota
Cummins 6.7 HOHD
Love my 3500 with auto leveling. Didn't do the cc because it didn't come with all the options. We tow a 27k fiver with about 5k pin weight. Wouldn't have done a thing differently for us
Administrator
If your really drawn to the 19.5" rims of a 4500, there is always a 10 lug conversion for a 3500 dually.
kevin1
kevin1
Maryland
v10
Thanks all for the info so far, so NH Ram said this:
Should I have a preference for either? Pros / Cons of each?
OC455
Central NY
Just a question for you, I'm assuming this is a going to be a dedicated camping truck? Wouldn't the Cummins be a better especially hauling a heavy truck camper?
Moose2
Iowa
The Cummins is great, I just can't justify it for my use.
Awe, Kevin, no need to justify in today’s world.......just do what ya please and money will just magically appear outta thin air...sorry for my twisted sense of humor!
olyelr
Kewadin MI
The 3500’s have leaf springs out back too.
ZB39
Earth
ISB
I ordered a 21 5500 for my Host Cascade. This is my 3rd 5500 for 2 different campers. I went with a steel CM SK bed. I attach the fast guns directly to the rub rails. 19.5, exhaust brake stays on all the time, no need to hit the button everytime, bigger brakes, higher GVW, tighter turning. Lots of reasons to get a C&C instead of a 3500. I owned 3 3500/s before I got into the 5500's. It rides great with the camper and without. I had kelderman put a 4 link air suspension on it front and rear. I can raise or lower every corner from in the camper. Also dual tanks, 74 gallons of fuel.
