35s and 3:21s
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
I am going to go bigger on tires and am looking at 33s or 35s and would just do 35s (after bils) but am worried about my 3:21s and if it now being geared taller will make my 7th and 8th gear about worthless.
Really figure the take off power wont bother me to much as its geared pretty low in first gear.
thoughts input on the matter.
I do have a like new Micky Thompson MTZ in a 305 and if I did that I can just buy the 35s for the 69 but really wanted to hear some thoughts on this from the guys that have already done this.
yillbs
8th gear will be useless, but I use 7th all the time. you'll get about 12MPG crusing at about 70MPH. I have 35's on Open country M/T Toyo's. I have 20" rims, with a 6" lift.
The 3:21 gears argument is moot with the 8 speed tranny. You'll see lots and lots of people talking about how 3:21 with 35" tires is bad, but that's mostly on the JEEP forums. If you see it on HERE, that's just because those people don't understand how gearing works with the final drive ratio. I posted a really good break down of how it works somehwere, i'd have to find it. However, you won't be disappointed, the get up and go, passing power, and crusing is nice. It's not going to be the HEMI you know and love, but it'll still be a power house.
Ferro
I have a 4 inch lift and I'm running 35's with the 3:21 I have no problems with it at all. The truck has no problem finding eight gear on the highway.
H3MI UP
Southeast ga
glad someone made a post about this as I wanted to know the same thing. I just bought a 2016 Ram qc bighorn with a new 6" lift and 35 12.50 20 nitto terra grapplers today. I didn't even think to check to see what ratio it had until I had already made the deal. Sure enough I crawled underneath and it's says 3.21. I hope you guys are right about this ratio with the 8 speed tranny. Hopefully it want strain the motor or tranny with the 3.21 gears. I don't know how the 8 speed tranny is geared. I got some reading and learning to do. Keep the info coming
69GWC
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
I know in stock forum my truck will light the tires up at 20mph and leave black marks for 30ft atleast and from a stop it just blows them off so easy so I fiugured take off would still be fine, but was am worried about hwy speeds and searching for gears.
I put 35s on my 07 Cummins and did not effect it at all but in 6th gear it was pretty much worthless unless you where doing 70+ but thats a different transmission.
Thanks for the info.
bubbagumpshrimp
Keep in mind that the vast majority of people that lift a truck and put bigger tires on it do not re-gear. It's something that the average person doesn't know about or chooses to live without doing.
Dealerships do the same thing. The ones in my area will take a stock Big Horn (3.21 gearing), put the 4" Mopar lift, and bigger tires on them. If there was an concern of reliability or potential damage, I doubt they'd set them up like that, warranty them, and send them on down the road.
Neumie
MN
5.7 8a
35's..
Couple questions for you on this--are you cruising at an actual 70 or maybe more like 75 because of no speedo adjustment? And likewise, are you maybe getting 13 or 14 mpg because of no odometer adjustment?
Thanks
Ferro
I could run 70 miles an hour with the cruise control set and I average 17 18 miles per gallon on the highway. I don't see how people say that eighth gear is useless I do not see that at all. Only time I see it being useless is when I'm pulling something.
69GWC
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
My worry is at 70mph that every time you lighty press the throttle it will down shift , basically search for a gear to stay in which is hard on the trans.
But if you guys are saying this is not the case that is great, just did not want to end up with a 7sp or 6sp because I went to big on tires..
Ferro
If you give it a little gas it will go down to seven gear. But it will go back in the eighth.
mpittman
Indiana
2015 Big Horn Crew Cab
Thanks
Just installed a 4" lift, and added 35"x12" tires. My speedo is 3mph off. If the truck says 67, I'm actually doing 70. I have tested it with two different GPS apps.
yillbs
Im in south texas, everything is some sort of hill. If you put it at 70MPH put it in cruise control, it will go to 8th gear, the SLIGHTEST blip of the throttle will push it back down to 7th. On a straight road, I can get EVIC 14-15MPG. However, those super straight roads are hard to time by. you will NOT be using 8th gear in hill country, at least not with a 6 inch lift, and 35" tires. On that note, my speedo is off by about 3MPH, meaning my MPG will be off, butit's very very slim. I JUST signed up for fuelly, so hope to get an accurate number soon, so take my 11-12MPG with a grain of salt. Even when NOT using cruis conrol, 8th is pretty useless, at least in my experience.
I can still light up the tires from a dead still. Mind you, my tires are extremely hard, and will spin under minimal throttle.
I've towed about 6k pounds with it lifted and these tires, and the thing drives like a champ.
yillbs
It will search for a gear, if you're in the hills ( even slight hills ). however, this can easily be corrected, set the max gear to 7th gear, no more searching. When i'm going to be on straight highways, i'll let it stay in 8th when possible, soon as I get into any type of hills, I'll just max it out at 7th. I have some videos of what i mean if you want to see them :)
yillbs
The rear end is only half the equation, final drive ratio which includes transmission gearing is what matters. If you have a lower gear ratio then you'll take off quicker but you will top out at a lower top speed. Rams are limited to 105 MPH anyway, but you can remove the limiter with a tuner. IMHO 4.88s with an 8 speed are unnecessarily low and will give you a 22.98:1 1st gear final drive ratio-you will probably shift out of 1st by the time you hit 3 MPH. If you have 3.92s i wouldn't waste money going any lower.
Many people are not used to newer transmissions that have a lot of gears and allow for a wider range. Back in the day when they had 3 or 4 speed transmissions you needed 5.88s to get a load moving with a tall 1st gear in the transmission, but that also limited your top speed. By gearing with the transmission you have a similar top gear (8th and 6th gear for the 8HP70 and 65RFE respectively are both 0.67:1), but a lower first gear (4.71:1 in the 8 speed vs 3.00:1 in the 6 speed).
If you had a 6 speed with the same final drive ratio in 1st gear that the 8 speed provides then your diff gears would be:
3.21 (8 speed): 5.03 (6 speed) differential
3.55 (8 speed): 5.57 (6 speed) differential
3.92 (8 speed): 6.15 (6 speed) differential
conversely, an 8 speed would have to have the following diff gears to provide a similar final drive ratio to the 6 speed:
3.21 (6 speed): 2.044 (8 speed)
3.55 (6 speed): 2.26 (8 speed)
3.92 (6 speed): 2.50 (8 speed)
Actual 1st gear final drive ratios for a given differential/transmission combo:
3.21/6: 9.63:1
3.21/8: 15.12:1
3.55/6: 10.65:1
3.55/8: 16.72:1
3.92/6: 11.76:1
3.92/8: 18.46:1
4.10/6: 12.30:1
4.10/8 (never offered, but demonstrative): 19.311:1
When have 5.03s ever been a necessary gear in a 1/2 ton? You can only get so far before you end up with such low gearing that the truck shifts to 2nd at 2mph or so. How useful is that gear?
Once you are moving and out of 1st gear it doesn't make much difference anyway as a truck with taller diff gears can drop a trans gear to accommodate. FWIW the trans gears for the 6 and 8 are, respectively:
1st 3.00:1
2nd 1.67:1
3rd 1.50:1
4th 1.00:1
5th 0.75:1
6th 0.67:1
Reverse 3.00:1
1st 4.71:1
2nd 3.14:1
3rd 2.10:1
4th 1.67:1
5th 1.29:1
6th 1.001:1
7th 0.84:1
8th 0.67:1
Reverse 3.30:1
Now compare this to Toyota, which I will use as an example because they offer only 4.10 or 4.30 gears in the Tundra which are very low. This is because their transmission gearing is so tall. With the 4.30 diff in a Tundra and their 3.33:1 1st gear you get a 1st gear final drive of 14.319:1
A Ram with the 8 speed and 3.21s has a first gear final drive of 15.12:1 as I said before.
That means if you have an 8 speed Ram with 3.21s it is actually geared lower than a Tundra with 4.30s.
Another thing, if you are going super low your ring gear will need to be larger or you will risk breaking it, which is one reason Toyota uses a 10.5" ring gear (and you can find accounts of theirs braking more than infrequently). We have 9.25" ring gears, so lower than 4.10 I would be concerned. I don;t know if a 4.56 or lower will actually fit.
Some of this is useless to you, as it was a direct copy paste from a conversation i had with someone else, but the general information is still the exact same. hope that helpswith understanding the gearing in the 8 speed.
69GWC
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
good info, this is the kinda info I was after.
Thanks alot.
H3MI UP
Southeast ga
3.21/6: 9.63:1
3.21/8: 15.12:1
3.55/6: 10.65:1
3.55/8: 16.72:1
3.92/6: 11.76:1
3.92/8: 18.46:1
4.10/6: 12.30:1
1st 3.00:1
2nd 1.67:1
3rd 1.50:1
4th 1.00:1
5th 0.75:1
6th 0.67:1
Reverse 3.00:1
1st 4.71:1
2nd 3.14:1
3rd 2.10:1
4th 1.67:1
5th 1.29:1
6th 1.001:1
7th 0.84:1
8th 0.67:1
Reverse 3.30:1
That makes a lot of sense. Thanks for sharing. I guess my little 3.21 gears are fine after all
Gump
Butte, MT
I get 17-18 on flat ground at 80 mph with 34.3 tires. Living in Montana though there isn't much flat, so it's typically 14. It doesn't have an issue getting to 8th on the flats.
yillbs
yup, obviously that chart is still a little off due to larger tires, but overall, you're fine. It's fun looking down on everyone :) literally
H3MI UP
Southeast ga
lol I was thinking this yesterday as me and the wife were riding down the road. This is my first lifted truck and I loving it so far.
Steve58
