392 stroker 0-60 time
Belgiquebasterd
Belgiquebasterd
Inertia 392
Yeah something is definitely wrong. My truck bone stock does the 1/8 mile in 10 seconds flat
I see in your sig that yours is a 2012, isn't that a 392 from the factory with variable valve timing and stuff?
ATXHEMI
Round Rock Tx
2012 is still a 5.7 it just has more power. And no you cannot remove the front 02 sensor. That the one that controls afr.
Belgiquebasterd
Belgiquebasterd
Inertia 392
Will play around with the O2 sensors when I have some time, see what codes it throws when I connect one or two.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
What are you using now for tuning? Stu from Inertia who sent you the motor parts and prob a DSP or Sean trying to tune Stu's motor with a DSP or SCT? I know a decent amount of background on your build just trying to get as much info on the table.
Belgiquebasterd
Belgiquebasterd
Inertia 392
Parts came from inertia, he got a bit swamped with work so I wen't to hemifever for tuning to speed the tuning up. Tuning is a custom tune with the diablo predator.
My situation is a bit unique, most people who go stroker already have an extensive mod list. I kinda was forced to go the stroker way after my bone stock motor seized. Reason for bringing this up is that I'm still running the stock exhaust manifolds and 2 into 1 pipe, while I'm guessing that nearly all the other strokers are running headers. I'm thinking that this combined with the cat overtemp protection is the reason for my lack of power. (Stu even thinks that the bad flowing stock exhaust manifolds might be a reason for the high exhaust temps.)
HemiLonestar
Navy Badge Coast Guard
MD
SCT isn't compatible with the 03 hemi.
ATXHEMI
Round Rock Tx
You def need to get yourself some headers. I think you'll be pleasantly suprised how much you wake that thing up
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
2019 (2003 Forgottens SOLD and 2014 SOLD)
Hemi 5.7 (392 Hemi) 86 Ford .308 HO Roller
For an 03 Shorties or the Full Dynatec system with 02 extensions coupled with a good tune you may be able to live with the 5850 RPM and still be under 6 seconds.
Never Confirmed if they make an 03 set-up (one Cat and 2 sensors) as it comes with 2 high flow cats and 4 sensors and wiring (maybe it can be split?? or maybe just 04 and up?).
If you keep one cat get the choke point cut off near the end close to the honeycomb and get it to 3" like the stock pipe.
truckin151
2013 sport
What temp is it at while running? Exhaust temps that is
Belgiquebasterd
Belgiquebasterd
Inertia 392
When I go the header way I'll get a set of pacesetter headers and a homebuilt 2 in 2 exhaust, don't know if I'll go with an X pipe or a H pipe, still need to do my homework on exhausts.
Belgiquebasterd
Belgiquebasterd
Inertia 392
I'm guessing you desesenstized or turned the cat overtemp protection completely off? A tuning option that does not exist with the 03 pcm :Boo: (well for diablosport anyways)
Ran it with the both the rear O2 connected and disconnected but the value stays the same, guess it's the front 02 that does the temp reading. Anybody any ideas as how to get round this 'cat overtemp protection'?
Belgiquebasterd
Belgiquebasterd
Inertia 392
For those who care :), AFR video log, you can clearly see the 'overtemp protection' kicking in in 2nd gear and adding fuel in response to the high EGT's pulling the AFR down to 10.0 by the time I shift to 3d.
Stu recommended to lean it up a bit in 1st, that way when the pcm adds fuel the AFR won't go down all the way to 10.0, any thoughts?
Click to play:
truckin151
2013 sport
Don't think anything was turned off in the tune file.
topherztoyz
