3rd Brake Light keeps popping
Nado
Nashville
Hello - 2015 Ram Sport with LED lighting. However, my 3rd brake light (upper) appears to pop too frequently. 4-6 months. Is this common? I was thinking about swapping it out to an LED bulb. But, wanted to make sure there isnt another issue.
Thanks!
VB712
Maxi_built
Va Beach
Very well could be getting water in it. They are prone to leaking.
Boston, MA
2014 Crew Cab
5.7L V8 HEMI
Replace the glass bulbs with a decent LED. Then apply a thin layer of foam weather stripping around the trim where it sits on the paint.
Remember: red LED’s behind red lenses for vivid bright color.
I use this brand. Very bright, instant on for safety / visible and 3 year warranty. Plug & play.
https://www.vleds.com/shop-bulb-numbers/921-led/921-6-r.html
Badger 13
North Idaho
2013 Dodge Ram 1500
I agree with "Sheriff Justice", and while you have it off, you could replace the cargo light bulbs with LED's as well. It sure lights up the back .
modstang
Kansas
5.7 Laramie
All great suggestions here. Weather stripped beats a caulking suggestion I've seen (relies on trusting the LEDs to last).
Davidloveshishemi
Tn
2019 Ram 1500 Classic
5.7 L Hemi
Just changed my weather stripping for the 3rd brake light on my Ram today. Totally preventative what was cool is it literally took 5 minutes.
