4/6 drop kit questions
831718938
Illinois
IMG_4820.jpegThis is my ram , I bought a 4/6 drop from ihc . Need help figuring out how I can lower the back to achieve the 6 inch drop in the back.
MarshRam
2014 SLT 4x4, 2012 ST
The rear is the 6" drop, the front is the 4" drop, I.e, 4/6 drop. You're golden, level! Unless there is a total misunderstanding in your messaging, you're good. Going to look great on a SC Ram with some SRT Rims! It sure looks like someone already lowered it, the front at least. That's already sitting lower in the front than my 2/4 drop with 22" SRTs on 285/45. I'd check on that, you might only need to deal with the rear and return that IHC parts order?????
831718938
Illinois
I bought the 4/6 ihc kit and put it on , but the truck doesn’t have the 6 inch drop in the back. The truck looks like it’s sitting on a 4/4. I put the kit on exactly how the instructions told me but only thing I didn’t do was cut the springs. Just wanted to see other peoples opinion on how I can go lower the back.
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
You have to cut the supplied rear springs. Out of the box. They are 4 inch drop springs.
Cut 2.5 coils from the right (passenger) and 2 coils from the left (driver). That should give you approximately 1.75 inches of additional drop. You can then cut more if you want. If you cut more. Cut 1/2 a coil at a time.
The reason you cut them differently is compensate for the weight of the fuel tank.
Here's mine. I have a half inch rake rear to front.
I'm down 4 in front and 6 in rear
Eric TOW
