4.7 with p0300 random misfire code
SD4019
Wills Point, TX
Hemi 4.7
Got the cel today. Has 216k on motor. Plus fairly new with around 5k on them. Won’t rev above 4000 rpm. Randomly the truck has a lag starting (like a few seconds of turn over then it starts). Seems like solutions are all over the place. Where should I start? Definitely don’t have money to throw at it chasing parts.
Sherman Bird
Houston, Texas
Start the truck and let it idle..... allow the idle to get settled down.... Take a piece of notebook paper and put it up against the tailpipe opening flat. If the exhaust tries to suck the paper back in a split second every revolution, you have a miss..... if NOT, the P0300 is a phantom code for another problem such as clogged catalytic converter, fuel pump/injector problem..... and so forth. You need to get it diagnosed!
