4 high and low flashin
Bones2133
Cheyenne, WY
4x4 high and low ranges flashing on panel. Will not engage
CVX20
Ont,Ca.
2019 Classic Express
More than likely an issue with the motor/actuator on the side of the T-case.
R
Rampower2012
Guest
Or it just need to be servicesd and you can reset it aswel that is a sensor located behind your grill you just unplug it and plug it back in that well reset it. On a 2012 that is how you do it
Moose Knuckle 34
Boondocks
Hemi wit Footprint gas pedel
Dumb question but did you try engaging in while in 2wd going over 2-3mph?
This is when it should be engaged. Might wake it up. Owners manual says to engage it this way. Hope it helps
CVX20
Ont,Ca.
They tell you this because sometimes the gears won't mesh when nothing is turning.Square cut gears will sometimes just butt up against each other instead of engaging depending on position.
