Tailgate not closing
JcsMI
MI
All of a sudden the tailgate will not latch. I cannot find an obstruction. There was a jack back there that may have slammed into the tailgate. It opened fine. On the drivers side I can get the latch to engage while open with my finger. But it will not engage to close. I tried lifting one end of the gate off of the hinge and then putting it back on but that dis not help. Anybody have an idea of whats wrong?
turkeybird56
Central Texas
Hemi 5.7, Non E Torque
Hey new here! Try some WD40. I had issues with my old eco diesel latch. That fixed mine
:welcome: London, KY, London, England??? lol
stenerson
New Hampshire, USA
3.6 VVT
J
JcsMI
MI
I sprayed the wnd with liquid wrench. I can only get the passenger side off. The drivers side is stuck. I tried plong and yanking. Tomorrow I may try a hammer.
Burla
Army
2010 Hemi Reg Cab 4x4
Good time to go nets.
J
JcsMI
MI
found a video there is a latch in side of the gate and it sticks. got it closed
njjeff201
Sparta, NJ
5.7 E Torque Hemi
I have the two way tailgate. If the computer doesn’t see all latches in their correct position it will not allow the release latch to function. ALL & I mean ALL switches/latches need to be soaked with WD40. If a switch is not in its correct position you cannot open the gate. I had a brand new 2021 & you had to SLAM it or the gate would lock out. Now I have a 2020 & it’s doing the same. Somewhere I read of a recall but know RAM I doubt it.
There should be as this is a common problem
Just a little tidbit for you,WD40 is not a lubricant,it's a Water Displacement formula #40 to be exact. You'd be better off using a good quality penetrating oil instead of WD40
RamCares
n/a
n/a
We can check for any potential recalls, TSB's or STAR cases associated with this concern. Feel free to DM us at anytime with your VIN to check.
Chris,
Ram Cares
