4 x 4 vibration after leveling kit
quietpeen
2021 TRX
Hellcat
Has anybody with a 4x4 installed a leveling kit and not have the vibration or shake when in 4 wheel drive?
Ram_bo06
Boston Ma.
I've not had any vibrations in 4wd after my install. Been about a year since installed. I've used both hi and lo with no issues.
glass3222
Central PA
Did you get it aligned after the level was installed?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
I don't have any issues. 4x4, HBS 2" kit, aligned at the same shop that did the install.
Musclemckeester
Houston, TX
n/a
n/a
Only had my 2" level kit for about 3 months and I can count the number of times I put it in 4x4 on one hand, but I don't remember having any vibrations. Now that I've installed the Bilsteins on the front, I do have vibrations at low speeds in 4x4. Figure that one out.
glass3222
Central PA
Between your Bilsteins and lift your CVs are probably at an angle that is causing the vibrations.
Musclemckeester
Houston, TX
n/a
n/a
That's probably true. My CV aren't as bad now as they were then though oddly enough. Still I'm only using 4x4 when I really need it so it doesn't bother matter to me.
quietpeen
quietpeen
2021 TRX
Hellcat
i could have sworn i replied to this earlier, but i guess not..LOL
I don't have a leveling kit yet. I'm trying to see roughly if the odds are more for having the vibration after level in 4wheel drive or less.
durango4819
DE
4.7 V8
i dont ever get it with my RCX 2.5'' leveling kit on or offroad. the only people ive heard that get it are using 4x4 on pavement but when do you ever need it then :Nonono:
quietpeen
quietpeen
2021 TRX
Hellcat
lol...in the snow
LB3711
Trumbull, CT
3.6L V6
I'll find out this winter. Hopefully we don't have another winter like last year. That was a *****.
Sent from my AT&T iPhone 4.
LoadedLaramie
Columbus, IN
the issue isnt if you have it, its when youll get it.
these front IFS systems are the EXACT SAME as the 3rd gen, and its all about when the right amount of wear allows that vibration to take place.
my 06 didnt have it then as the year went on with my 35"s it got it and it got worse and worse finally to the point i was going to replace my entire front end components.
for those with 4th gens that say they dont have it, ask how many miles they have? if you dont have it you will. there is no flaw in the IFS its just the way all the geometry lines up and when some parts move just a bit to create a vibration from the front drive shaft through the front end.
my 09 only has a 2" level and it didnt have a vibration before but it did instantly the day i installed it. its not bad but i know it will get worse so front end parts (MOOG FTW) will be in the future.
and yes i agree you shouldnt need to use 4wd on pavement. and if you cant feel it when your offroad thats prolly because you just cant tell the difference from the uneven ground.
the only common factor in all the stories of 4wd drive vibration is time wearing on parts. some dont have it with some levels, change to another whether it be larger or smaller and then they get it. when you take the IFS apart you put a small amount of wear into the parts from dis-assembly, factor that in with the wear allowed since you first installed the level and it will cause issues from then on.
you dont have yo believe me on this but ive seen it happening on forums for the last 3 years and ive had 1st hand experience with it twice. fact is all parts wear out. in these trucks that cause a 4wd vibration.
ramhunter9
P-Star Jeep Wrangler
Butch I would look into the HBS kit like JJ has ... seeing his truck in person it looks great
LoadedLaramie
Columbus, IN
from all the leveling kits ive seen the HBS ones are the strongest made. this is the 2nd kit ive bought from them. I believe jeremy had one on his 3rd gen also. great company and great product from them.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
Yup, I stuck with what I knew.
Well.........I looked. The funny thing? I noticed that HBS showed a different part number for the kit for 08.5 and up. I asked them about it - they said half way through the 08 model year a plate was removed from the top of the strut. They send a plate with the new ones to help make up that difference. No other company seemed to know there was a difference. HBS got my $$ again. :D
quietpeen
quietpeen
2021 TRX
Hellcat
I was def. looking into the HBS kits....have a link saved on my computer for them.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
I got mine on their eBay page, did an offer, saved me $5.
