46re trans issue, anyone have insight?
Noodle
Canada
magnum 360ci (5.9L)
Hello, i have a 2002 dodge ram 1500. 5.9l v8 and a 46re transmission. issue is this,
no reverse....
all forward gears work great, however reverse does nothing.
i have removed the pan and adjusted the bands correctly, 8nm and 2 turns back on both bands. reverse came back to life, put new filter and new fluid in it, then about a block away while driving the rear wheels locked up. reverse blew out again, truck still moves forward fine but reverse is completely gone. any ideas? I dont want to have to remove it but it would be great if someone else had some insight on these trannys. Oh and the kicker, 290,000km on the trans. worth re build/fix? new engine in the truck 70k ago. runs great, no rust decent interior and tight front end.
been reading up on the tranny and they are pretty simple, i just only have the one truck right now and need it back on the road asap!!
Lonny Graham
Apple valley ca
Just remember if you in to the overdrive part od it
The sprague has 800 pound spring need special tool cascade transmission. The front part of the transmission
Is easy
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
I'm not a guru on the 46re but this sounds like the low reverse servo cracked. Look up the symptoms on the internet. On the HTC forum we are using the 46rh behind boosted hemi strokers with sucess. Good luck..
