47RE TRANSMISSION FLUID CAPACITY?
DAVEH
MINNESOTA
V10
What is the trans fluid capacity of a 47RE in a 2001 2500 4wd with a V10, following a pan drop change.
The Haynes manual says approx 4 qts, I am now up to approx 6 1/2 qts. It shifts fine, but after warming it up, it still shows almost nothing on the stick. I am checking it running in neutral.
Thanks in advance.
DodgeTx
SEGUIN
5.9L Cummins, 5.2l v8
how did you drain your pan, from the return line? When I did it with stock pan 4 qts, with deep trans pan about 6.5.
If you just removed your pan changed filter and put pan back on, shouldve taken about an hour tops. then you only need the 4.
However if you let it sit for days with the trans pan off it's completely possible you need more.
Source of my knowledge 1996 dodge ram 8.0l v10 Dually Auto
