wrenchinup
After I replaced my wrecked DLD transfer case with a DHD transfer case, I found that the driveshaft ( regular cab one-piece shaft) could barely fit in. It drives OK for now but there's no room for movement. So I want to shorten the shaft but I'm also thinking I might swap my 47RH auto tranny with a 5 speed NV4500 manual, and I don't want to have to change the driveshaft length again if I do the tranny swap. So my question is what is, is there any difference in length between the Four Wheel Drive 47RH and the NV 4500? Thanks in advance
