4th Gen front door speaker wiring
Skyjockey
Lowell MA
2019 Warlock 4x4
3.6L
last piece of the puzzle. How did you guys route the new front door speaker wires from the cab to the door? Looks like the factory rubber hose is a bulkhead connector with no way thru? Hate to drill new holes just for better wires?
Someone must have changed their wires?
Etroze86
Grand Forks ND
its still a boot and you should be able to run wires through them cause i was able to on my 2011.
BlkRamRt
SoCal
HEMI 5.7
it should be easy i did it on mine. the boot on the doors has 2 screws remove them and you will be able to fish them through.
Thmupr
N. Texas
Here are some pics to help you out from when I wired my 2009. Should still be the same, my 2014 looks identical.
Skyjockey
Skyjockey
Lowell MA
2019 Warlock 4x4
3.6L
Thanks !!
I'll take it apart this weekend. Looks like you got lucky and only have 1 of the 2 connectors populated so that sure does help! Now to get around the parking brake bracket?
It amazes me the size of this truck yet every audio component is jammed into the smallest corners?
Thmupr
N. Texas
Pull the wire in the gap between the gray connector and the wire outer housing. It will make sense when you look at it. I pulled 14ga wire through, but it's tight. 16 or 18 gauge would be much easier. Look at the third pic and you can see the speaker wire between the plastic parts of the connector. I used a piece of an old antenna to help pull the wire through the rubber bellows.
