4th gen with G56...How to Enable the High Idle Function
Cwrogers927
Colorado
I have a 2013 3500 with a G56...I've looked everywhere on here and Google, and can't seem to find how to enable the high idle on these trucks. I did see some older post talking about a clutch kit, however they don't make those anymore, and also the ECM is different for my truck so the pin 22 that they said to ground, that would short out my ECM and cause damage, they changed ECM's in 2013 so that is no longer valid and mine don't match the ECM layout I seen posted. So I was curious if anyone knew how to Enable the High Idle Function on this year truck. I did go to the dealer and they hooked up to it and went under "enable/disable" function tab and they had 2 options under there, 1.) EVR Idle up and 2.) Idle shutdown. I did have them turn the EVR Idle up on and that didn't do anything (I had them leave it on too) so any suggestions would be appreciated, thanks.
RamDiver
Marlborough, Ontario Canada
2021 DS
We have already covered this discussion in the AlfaOBD thread.
Were you hoping for a different answer to the same question? :cool:
My apology, I see that you started this thread 20 minutes after your post in the AlfOBD thread and before any response there.
AFAIK, part of the TOS here is not asking the same question in multiple posts/threads but, you're new here. :cool:
Regardless, the practice is discouraged.
C
Cwrogers927
Colorado
Well I really didn't ask the same question twice, or even ask you at all, and you also didn't even technically "answer" the question at all either. The post in the alpha OBD thread was simply just asking if that specific individual (Rock$tar) had figured anything out yet, since he happened to be looking for the same thing that I was and I found that post in a search I did before commenting/posting anything at all, and since I was responding to a post that was from years ago(Feb 9th, 2019 to be exact), I figured it was a long shot so I went ahead and posted a simple question on here to see if anyone had any input...so maybe lighten up a bit.
C
Cwrogers927
Colorado
You can't on a manual trans, without a tuner.
It will high idle on it's own when warming up but that's about it unfortunately.
I tried contacting my tuner and they told me they can't do anything and to go to the dealer. Not unless your talking about setting it on the SOTF switch? I can ask about that but not my favorite option to be honest because then won't I lose a setting out of the 4?
nlambert182
Huntsville, AL
Probably.... it's a safety feature to prevent it from idling up and getting bumped into gear I presume.
Why do you need it?
C
Cwrogers927
Colorado
Why do you need it?
It very well could be, but sometimes the truck idles up on its own, so wouldn't that contradict that?
Well I live in Colorado and when its cold out I let the truck idle for extended periods of time sometimes to keep the interior of the truck warm for when I get back in. Sidenote that's kinda related is I owned a trucking company for about 8 years and I had a Kenworth with a 3406E CAT, and sometimes when it was cold (well below zero) or in the summer when it was hot, I would idle the truck overnight so I could sleep, well with that said CAT recommends that you idle at 900 and above to keep the cylinder temps up so you don't get fuel wash on the cylinders. So that's the reasoning behind it.
And yes for those of you that will say idling is bad, I seen Dave's video about idling and I think its a joke, I have over 802,000 miles on this engine with oil samples from CAT every 10k-12k since I bought it for those that say different and can post if there is any skeptics
nlambert182
Huntsville, AL
I don't think anyone said idling it to warm it up was bad. It's almost a necessity to warm it up. I've ran mine through both 15 minute remote start intervals quite a few times if the weather is super cold just to get it up to temp. Letting it idle for a bit while you get out to do something isn't the end of the world either. But idling it overnight or for hours at a time is pointless and can cause problems with the emissions system long term. It will idle itself up as it sees fit to get/keep the engine operating temp up. A manual high idle really isn't a necessity on these. It's really meant more for folks who have a PTO and needs to idle the engine up for that purpose though.
The 3406 ended production in 1999 and is pre-emissions so it's far less likely to have a problem with idling overnight than a 6.7 Cummins, 6.7 Powerstroke, etc... It's apples/oranges to a 6.7.
C
Cwrogers927
Colorado
There’s a couple things wrong with what you’re stating. The idling for extended period of time was not directed for you I said “for those of you Saying idling is bad” so I was just covering it, ahead of time since people on here like to nitpick my post part instead of answer answering the simple question of high idle yes or no. If you look up Dave’s shop in Utah, he said to start the truck and start driving immediately after only a few seconds. He even posted a Couple videos about it and there’s plenty of videos on YouTube with discrepancies.
Also, if a manual high idle is not necessary, then can you please explain why it is necessary for automatic trucks to have it? And if you say bumping into gear, you could do that while it’s idling regularly, so I see no difference than setting the cruise control and putting the truck in a high idle. Not sure if you know this or not but if the engine is rev’d up higher, it’s actually harder to “bump” into gear So your logic makes absolutely no sense. Think about how a synchronizer works, it matches the engine speed with the drivetrain speed, (Input shaft to The output shaft) so if the engine(input shaft) is going a lot faster than the drivetrain(output shaft), it’s going to be harder to match that speed(be forced into gear) so if you have an engine idling at 600 RPM and the drivetrain is going zero (easier to get into gear)
versus if you have it going 1200 RPM (spinning twice as fast) and the drivetrain is going zero it is a lot harder to match those speeds and “bump into gear” hope that makes sense.
The second thing is that I never said I was going to idle this pick up truck overnight. I really wish you guys would not twist people’s words this is just ridiculous. I literally said “sidenote” when I was talking about the my semi, and idling it. I had no choice to, when it’s -30 in Wyoming… you asked why I wanted to idle it up and I was giving you where I learned this from. It rolled over from the trucking industry. If my semi truck sat for more than 20 minutes, I always idled it up.
Now, as for the pick up truck I said I’d like to idle it up and keep it warm while I’m outside working in the cold so when I get back in, it’s warm and I don’t have to wait. Not one single time did I say I was gonna run this pickup truck overnight. Also, I don’t have any emissions on the truck if you must know. I just wanna clean burn and to idle up my truck for maybe 1 hour to 2 max without fuel washing my cylinders and getting a complete Clean burn
nlambert182
Huntsville, AL
Spent a large part of my life in and around the trucking industry. I am more than well versed in how it works. I simply answered the questions as you presented them. If you didn't comprehend what I and others have said, that isn't on us. The question was answered in post #2 above.
You ended that sentence with "That's the reasoning behind it", which could only lead to the conclusion that it was on your mind.
I said:
I don't think anyone said idling it to warm it up was bad..... But idling it overnight or for hours at a time is pointless and can cause problems with the emissions system long term. It will idle itself up as it sees fit to get/keep the engine operating temp up. A manual high idle really isn't a necessity on these.
I said:
"It's really meant more for folks who have a PTO and needs to idle the engine up for that purpose though."
If you want to know the WHY.... a quick google search provides the answer.
"Manual transmission Cummins trucks often lack a high idle feature because of the clutch safety switch mechanism, which prevents the engine from going into high idle unless the clutch pedal is fully depressed, making it impractical for manual transmissions where the driver needs to operate the clutch frequently; essentially, the system is designed to avoid unintended acceleration when the truck is in gear while idling high"
Does this help clear up any confusion?
C
Cwrogers927
Colorado
I said:
You said:
It’s funny how you say if I didn’t comprehend what you or others have said. You clearly don’t have or ever owned a G56 in your trucks and also haven’t researched it beyond a 2 minute google search. So why are you even commenting then? Does it make you feel like your contributing or something?There are ways to get it done and I will attach the file so maybe you can learn something new, I’m just trying to find the correct ECM pin out sheet to ground what terminal to get it done in a factory way and not an aftermarket way.
And to answer or clear your confusion to me saying “that’s the reasoning behind it” you clearly left out a huge part in that…was when you asked me why I wanted it done and what I was referring to was I want to idle the truck up to increase cylinder temps to prevent fuel wash and get a cleaner burn. As stated above. If you’re going to quote stuff do it correctly please instead of trying to make yourself look better because you can obviously tell the reason I wanted it was to increase cylinder temps so you don’t get cylinder wash…hence the “that’s the reasoning behind it” not to idle the truck all night long common man use some common sense.
No point in going in circles with you for no dang reason at all when you clearly don’t know what you’re talking about. This is posted from another forum I found, but my ECM has a different pin out so it don’t match and I’m just trying to find the correct wire on mine.
So now your statement of:
So here is the complete full write up on how to do it…WITHOUT a tuner Enjoy!
Manual is a 2 step process. I saved this from another forum. AlfaOBD is the dealer step in the ECU.
this is how to do it on a 6 speed.... thank DTR member "wagonfixin" he is the one who wrote the instructions below:thumbsup
So not to confuse the Dealer when he tries to enable the High Idle in the ECM, it's best if you've electro-mechanically "enabled" it first with either Step-1 or Steps-2 thru 3;
1) Buy the $200 clutch-switch kit from the dealer (currently discontinued) and install as instructed. - Pass Go - straight to Step 4…
2) Install a "dummy" clutch-switch by shorting the ECM connector-B Pin #22 to ground as follows: (Note this probably circumvents someone’s concept of safe power-train operation as depressing the clutch with this method will not disengage the high-idle "cruise" setting)
2a) Buy a new ECM connector pin (I bought the Cummins Pigtail part number #3164263 for ~$10.00+tax at a local Kenworth dealer) or use an old junk yard harness to salvage a single pin with a ~6"-7" lead.
2b) If you bought the pigtail #3164263, thelead will be too short, so pick up some 18AWG to extend the lead length. Thepigtail already comes with a crimp connector and a heat shrink insulator ready for the extension-lead.
- Crimp the ~5" 18AWG extension-lead into the pigtail and hit the heat-shrink sleeve with a heat-gun (or a lighter!!) Please check your own extension-lead lengths beforecrimping - this ~5" is from my lousy memory !!
- Add a 1/4" ring terminal to the end of the extension lead (this'll connect to a groundpost) - I bought the ones with a semi-clear blue "plastic" sleeve, the sleeve is actually a weather-proof heat shrink. Hit the heat-shrink sleeve with some heat.
3) Remove plug B on the ECM (the 50 pinconnector on the drivers side of the engine closest to the rear of engine with a 4mmAllen screw in the center). Note: this isprobably best done with the both batteriesdisconnected first (I did mine with thebatteries connected - sloppy).
3a) Push (use a paper clip) the sealing plug out of position #22 (starting at to left, count across, there are 50 pins total, #22 is second in from left, third row down) Note:#22 is the PTO/Clutch switch sense terminal (page 8W 80-98 in the shop manual).
3b) Insert the pigtail-lead into the back of the #22 until you feel a positive detent (click), lightly tug the wire to ensure that it's been properly inserted and cannot beremoved. Note: Make sure that you've properly identified #22 - if you've put it into the wrong position, you'll probably need to head over to the dealer to use a special pin removal tool...
3c) Reconnect the ECM connector, don't bother trying to push it on, just seat itsquare on the ECM connector, and carefully thread the 4mm Allen screw until it bottoms out.
3d) Slide the ring-terminal over the lower-left post of the ECM retaining stud (mine stud had an extra ~1" of available thread)
3e) Add a 1/4-28 fine-grade nut to secure the ring-terminal to the ECM retaining stud, torque to... - oh hell - just tighten it !!!
3f) Reconnect the batteries if disconnected.
4) Take the truck to the dealer to enablethe High Idle option. On older models, I think it's an actual TSB (18-004-04) to flash/load the ECM - my '06 just needed it to be enabled.
- If your tech can't figure out what/where a high-idle is (mine didn't know) tell him tofollow these menu options (I think these are from the DRBIII and not the Star tool which they used on my '06)
- With the ignition in the “RUN” position, using the DRBIIIT select:
-> DRBIII Standalone
-> xxxx - xxxx Diagnostics
-> All (Except Below)
-> Engine
-> Misc. Function
-> Idle Up Feature Enable (the option is in the same place as the daylight running lights)
- Ensure that the after the flash option has been loaded to the ECM (TSB 18-004-04) that it also activated - this is a additional step !! Again - note that on my newer '06 they just had to enable it - not flash it as a TSB !!
5) If your tech knows his ABC's - he will know how to verify if the high-idle has been properly loaded/enabled - if not, here's how the high idle on my 6spd worked:
- Start truck.
- Stay off the clutch (if clutch switch was installed) and service brake pedals(recommend setting the parking brake on your 6 speed !!).
- Turn on "cruise".
- Hit "set".
- The engine should come up to 1,100 rpm.
- Then hit or hold accel;
- Each time you hit accel momentarily itshould go up 100 rpm (Max is 1,500 rpm).
- Each time you hit decel momentarily it should go down 100 rpm (Min is 1,100 rpm).
- Hit the service brake pedal, the RPM's should drop back down to the normal ~750.
- Hit the "set" button, it should run back up to 1100 rpm.
- Hit "cruise" to turn off cruise and the RPM's should drop back down to the normal ~750.
6) If you have any follow on TSB's that flash the ECM, remind the service manager (or better yet the tech) to ensure that high-idle is to be re-enabled following the TSBflash. Mine was disabled after applying the 18-003-06 hard-start TSB last week.
7) Smugly recall the fella who posted hisstout-lumber stick "High Idle Management Interface" picture next time you're at a longlight out in the flatlands and hit your"Cruise, Set" buttons... Don't roll into theintersection !!
RamDiver
2021 DS
With an attitude like that, good luck finding anyone to help you with much of anything.
We're a social community looking to learn, assist others with learning, and to have fun in the process.
Most of us have no interest in a bad attitude or arguing the size of our personal anatomy.
I'd say you're not in the right place.
Best of luck to you.
C
Cwrogers927
Colorado
lol, I was fine until you started twisting my words and took things out of context, then proceeded to act like you know what your talking about when you don’t.
If you can’t answer the question then why even reply?? Seriously man…I really don’t see where you tried to help me assist with learning anything besides shutting down what I wanted to do from the beginning by saying it can’t be done.
You tried to tell me if I was to do a google search that I’d answer my own question that it can’t be done, then tried to act like you knew what you was talking about when you’ve never owned a manual transmission in a Ram truck, but I post a thread of how to do it and show you that it can be done, and now all of a sudden this ain’t the right place for me lol.
If you don’t know then why bother trying to comment and acting like you do? Would’ve saved you and I both some time.
I didn’t know you were the speaker for the whole forum by saying this ain’t the right place for me to be? But maybe you’re right, you guys are way too sensitive here and jump to conclusions.
nlambert182
Huntsville, AL
Well aware of how a G56 works and yes, I've spent a lot of time driving a truck with one.
Pretty positive I mentioned the clutch switch above.
Which is WHY it isn't an option on manuals. Pretty positive that you asked WHY... and I explained why, and looks like it was reiterated in your post.
-> Engine
-> Misc. Function
This is tuning the ECM, you do realize that right? The only difference is you're having someone else do it versus a tuner... so a tuner is required. WHO has the tuner is the only difference.
The problem is how you interacted. We ARE a community that tries to help people, but if you come in here and ask questions which we try to help answer and then give these types of responses, expect it back. WE don't have a problem and were trying to respond to help YOU with yours. If you can't be a little more humble about it and want to get spun up because we don't tell you what you want to hear, then RamDiver is right... maybe move on.
If you knew what do you you wouldn't be here asking us. We're all trying to solve the question together. You realize that, right?
man n black
Cummins
I'm only replying in hoping to put to bed some of the bickering.....
FWIW.....I lived for over a decade in Routt County with my 2013 automatic equipped truck where it was commonplace to delete emissions on Cummins trucks bc there was no emissions testing...
In all those years driving that truck through the winter I never had a problem returning to a cold cab even after extended time away (4 hours or more on some occasions). On many days I would have my dogs in the truck too and they tolerated the cab just fine in the deep winter months, actually kept it warmer than if by myself. Pretty much the only time the truck would high idle was at first startup of the day.
I imagine @OP your experience will be similar.
Cheers;
Ch
