rambob
straight forward....
the front driveshaft turns while in 2wd and apparently it should not
I believe the transfer case is not disengaging the DS
when shifting into 4wd, it does it easily. I can tell it changes to 4wd, I.E. the vacuum engages the axle shafts.
I am thinking of pulling out the front DS until I can solve the transfer case problem b/c I dont want the shaft spinning to damage anything inside the dif or whatever. I believe this is the cause of my noise.
opinions???
opinions???
