4wd help please
ccarlson599
1999 sport
hello I just bout a 1999 ram sport 5.9 magnum when I drive in snow In 4wd steering will pull to the sides if I drive 30mph its hard to control any info would be appreciated thanks
SportRam00
Joppa, MD
Magnum 360
I would check your track bar, ball joints and tie rod ends for any looseness. Any of the parts will cause steering wander if they are worn or failing.
Put the truck on dry ground and have a partner slowly move the wheel back and forth. Look for any parts that are moving or loose.
I have found that my truck in particular is sensitive to road crown and will slightly pull depending on which side of the road I'm on.
C
ccarlson599
1999 sport
thanks it has new ball joints it only happens when I lock it in 4 hi or 4 lo its hard to handle it pulls hard to either side I don't dare to go over 30mph
MADDOG
Living in a Firepit
6.4L HEMI
The track rod is probably the culprit. The 2nd gen trucks are notorious for that.
