5.2 more power
heminutt
i have 99 ram with a 5.2 i am looking at getting a tunner for more power.
i have cat back dual exahust on it. so what would be my best bet for a tunner
Blackram
Add some HS 1.7 rr's for some easy bolt on power. Nice mod for the older magnum engines.
WhiteExpress
Midland, TX
There is a lot you can do to the ol Magnum motors.
First thing to do is make sure you plenum gasket isn't leaking.
Just fixing that can net you a decent increase in power.
I ran a Hypertech on my '00 Ram, and honestly I couldn't tell it did a damned thing other than help the shifting. But that's the main thing I wanted so...
WhiteExpress
Midland, TX
what is this. and sct dont make a tunner any more
Harland Sharp Roller Rockers.
The stock rockers are a non roller design with a 1.5 ratio.
Going to a roller 1.7 ratio will give reduce valve train loss and effectively change your cam profile to somethine more aggressive (valves open more, stay open longer) without having to do a cam swap.
The cheaper version of this mod is to order up Gen I Viper rocker arms (still non roller) but they are 1.6 (if I recall) and drop right in quick and cheap.
Blackram
They are the best mod I ever did to my old 2nd gen ram. Better gain than intake, exhaust, tuner, larger tb, any of it. And they are a basic bolt on mod, easy install with great results.
H
heminutt
ok i talk to sct they do not have any tuners for my truck any more. is the edge tuner any good. and were would be the best place to buy the roller rockers
Blackram
Summit has them.
H
heminutt
ok so what would be a better tunner the edge or super chip
H
heminutt
i talked to hemifever and he said they are no longer making them.
