Wahrsuul
- Nov 16, 2011
- 2,779
- 8,613
- Location
- Central S.C.
- 2019
- Hemi 5.7
Ok, I did a service on my trans over the weekend - pan drop and new filters, put in around 6 quarts of Valvoline ATF+4. Trans seems to be shifting fine, but the manual says to check the trans hot - what temp is that? Seems mine gets to about 12-125 on the way to work, is that hot enough? Want to make sure I have enough fluid, but not too much.
When we dropped the pan, the fluid was a bit dark and according to my brother, "starting to smell". Not sure it it's ever been done before, but according to the manual 120k is the first service?
Anyway, I'm thinking I'd rather do this a bit more often, so is there a way to put in a drain plug to make this less messy? I've read of a few guys changing fluid every 15k, and filters every 30k. Excessive?
