Transmission fluid 1/4” above full mark
2018Hemi
Wauseon
Posted couple weeks ago about leaking transmission fluid from bad pan gasket. Had new gasket put on and now it shows 1/4 or so above full mark hot. Should I extract some to bring it below the hot mark or is it good. What a deal
Thanks
Grams
2024 & 2015
6.7 Cummins & 5.7 Hemi
Leave it alone.
2018Hemi
2018Hemi
Wauseon
Thanks so you don’t see a problem with that little bit above
turkeybird56
Central Texas
Is that check with trans hot or cold? Also parked on level ground?
turkeybird56
Central Texas
IMHO that 1/4 above OK on tranny stick, but I am no mechanic, but for years I had mine somewhere in that area cept now of course who knows. NE way, AS stated, if U R concerned, just take some out till U get it a smidgeon below full line. Wateva U do, do not take ne thing said here as gospel, if U R concerned at all, take some fluid out.. Does you truck have the 6 or 8 speed?
Not sure wat year they switched to the 8's for the Bigger Hemi's.
2018Hemi
2018Hemi
Wauseon
Mine is the 6 speed. 66RFE transmission. Thanks
