6.4 crank but no start
Van7559
Peyton, Colorado
Every now and then I will crank my truck in the first time it cranks it will not start any ideas? Usally turn the key off and itll fire the 2nd time? 56k
Docpaulo
Battery or starter... check connections for corrosion
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
Do you turn the key to the on position first, let the fuel pump prime till it shuts off, then go to the crank position? I always do, never a problem like thst
bigdodge
I've had batteries do that. Turns over fine but it would crank longer than normal. Got worse and I finally replaced it even though it seemed fine and the problem never came back. That happened on the stock battery
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
this also! I had this issue in the past also. if the battery has some age on it, if your battery is the original, pull it and have it load tested
V
Van7559
Peyton, Colorado
I checked the terminals for corrosion, and it looks brand new. It is the original battery.
Don_T
If it is a ‘14 model as it looks, you should get the battery load tested. It has been around long enough to be a possible problem Auto parts stores can test it for you, usually free. Make sure you disconnect it from the truck before testing or the test is no good.
V
Van7559
Peyton, Colorado
Checked the battery 12. 4 volts. Checked while starting, didn't drop below 10.9 volts and of course fired up without issues. I'll check again in the a.m. when it's been cold all night
V
Van7559
Peyton, Colorado
Check several times and battery is holding a charge properly, it has become very hit-or-miss
V
Van7559
Peyton, Colorado
Didn't check that. Any particular way I need to do This? I have an amp clamp that I use for my hvac profession
V
Van7559
Peyton, Colorado
P0456
P0441threw both of these codes. But ran fine. Both pertain to the evap side of things
