UPDATE:Update: It's February. LOL
True.I see no benefits to a drain plug. The cover should come off every time anyway to inspect the gears.
That is JMO^^^
This is a fact \/\/\/
And the shape of the OEM diff cover is like that for a reason. That half moon shape you see on the OEM cover. Its there so the ring gear can shoot gear oil right up it and that shape directs the oil up and over the ring gear and forward to the pinion gear to lube it.....it also ads in sending oil to the channels that direct oil to the the bearings.
No aftermarket diff cover mimics that shape.
My OEM cover is staying on.
Watch banks videos on the covers. I honestly dont like the man much but what he explains makes complete sense
Ahhhhh, only 4 more and you feel the power just drop out. It pulls right to 104 then just stays there. Never see 105. Did it , don't want to do it any more.I was passing someone on a two lane here in NM and looked down and it was at 100, holy ****, LoL.
2018 2500 6.4 4x4 4.10 Amsoil SS 0w-40, Softopper
Black Rhino Armory 18x9 +12mm
Cooper Stt MAXX LT295/70R18
2016 Durango 5.7 AWD 3.07 Amsoil SS 5W-30
1996 Nissan Altima 2.4 Amsoil SS 5W-30
Here's a little chart I made. I'm running 4.10's with 33's (275/70R18) stock size. I used a RPM calculator off of one of the gear sites I looked at. Your going to be approximately 150 rpm lower than these numbers with your 35's and 4.56's.
4th Gear, RPM's
R&P 60mph 65mph 70mph
4.10 2505 2713 2922
4.56 2786 3018 3250
4.88 2981 3230 3478
5thGear, RPM's
4.10 2054 2225 2396
4.56 2284 2475 2665
4.88 2445 2648 2852
6thGear, RPM's
4.10 1553 1682 1812
4.56 1727 1871 2015
4.88 1848 2002 2156
I believe I'm reading this correctly, you calculated the RPM's based off the stock tire size correct?
Hey everyone, been reading up on all the posts related to re gearing and the 6.4 hemi. I am very close to pulling the trigger on some yukon or aam ring and pinions 4.56's. I currently have the stock 3.73 and I have the stock tires and rims, I believe 20"
I am doing this to increase towing capacity so I can jump from my current 9K TT to a 13K fifth wheel. Getting quotes now, much on the higher side that what I am reading on posts a few years back, but looking between $2600-$3000. Any new feedback on your outcomes? One guy told me I wouldn't be able to go over 65 mph with those gears!?! I cant picture why or if that is even true. Hit me up with some feedback so as to help me finalize my decision!!
4th Gear, RPM's
4.10 2505 2713 2922
4.56 2786 3018 3250
4.88 2981 3230 3478
5thGear, RPM's
4.10 2054 2225 2396
4.56 2284 2475 2665
4.88 2445 2648 2852
6thGear, RPM's
4.10 1553 1682 1812
4.56 1727 1871 2015
4.88 1848 2002 2156
How would this chart look if I were running 37’s on 4.56 gears???
- The Blue Mule
The engine produces peak torque at 4,000 RPM's so having the gears and tires keeping it under 2,000 RPM's is like throwing away half the power of the engine. If you look at peak horsepower the situation is even worse as the engine peaks at 5,600 RPM's. By the way, this information is helpful when towing or carrying a heavy load.
Swapping 3.73 gears for 4.56 gears will only make an already very bad setup all that much worse.
Looking at buying a toy hauler that has a gvwr of 13,500lbs.
I won’t max it out but 13,000lbs is likely.
I have an ‘18 6.4 with 4:10’s. If I’m not happy with the pulling performance I’m going to consider gears. I’m wondering if 4:56’s would put my first gear final ratio close to the new 8 speed?
after looking at the chart on the first page. I’m thinking 4:56 would be best. I tow at 60-65 tops. 4:88 might be to much?
how big of an improvement can I expect? If I’m going to spend $2500 I sure in the hell better notice it!
I’m on the west coast and pull some big hills. Cajon Pass and the hill from bishop to mammoth are the norm.
Not afraid of the RPM ideally I would want to be in fourth at 60-65mph. I was thinking the 4:88 might be to high and it would want to shift to fifth. Obviously I can lock out 5th and 6th.4.88 are NOT to much IMO. Towing that weight the hemi NEEDS higher RPM. Dont be afraid of RPM if you want to tow heavy with a gasses HD.
