6.4 Hemi Gear Swap
pytbul
Utah
ctd, 6.4 Hemi, 4.56 gears
I changed from 3.73 to 4.56 gears on my 2500 with 6.4. totally changed how the truck drives. I live in the mountains and pull a 10000 lb 5th wheel. Mileage changed slightly to the better. I pretty much cruise at 65 mph and can stay in 5th gear instead always being in 4th. The only time I don't like the gears is when we travel empty on I-15 where the speed limit is 80. But still not bad.
M
mtofell
God I hate to hear this..... I know I would like my truck so much better with those gears. I'm frustrated that I can't trust the longevity of my truck enough to sink the money into it (tranny blew up at 40K as still doesn't feel right but that's another story).
Did you get it done at the dealer? My dealer told me the only available gears were the 4.10s and it would be around $3500. Of course, they are somewhat lost about things so that well may be inaccurate.
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
The dealer is definitely inaccurate. They're probably looking at just OEM replacement parts which would in fact only be 4.10's. I'd highly recommend having an experienced gear shop do the work. For one, they can get you whatever you want. Two, they'll make sure the gears are set up properly (I wouldn't trust a dealer to do that). And three, they'll be cheaper.
M
mtofell
I'd mainly be going the dealer route to keep my lifetime warranty intact. I suppose the gears wouldn't be that big of a deal to fall out of warranty. I wonder if they'd void the warranty on other parts because of the swap? Are there any outward signs of the swap or would they even know?
loveracing1988
Clarkston, MI
Short of opening up the axles they would never know.
Sent from my Nexus 6 using Tapatalk
pytbul
Utah
I had a local shop do the swap. $1650 front and rear.
pytbul
Utah
I had a local independent shop do the work. $1650 front and rear with new bearings and seals.
14RAM4X4
Sweating somewhere in South Texas
2015 RAM 2500 4x4
6.4L Hemi
A few questions about your gear swap... * first, are you on stock tires or larger than stock (what size)?
Then:
1 - What are your rpms at 65, 70, 75 mph?
2 - Did the gears make a big difference on daily drivability with the trans shift points?
3 - How is it at holding speed on the hwy (65 - 75 mph)?
4 - Any increase / decrease in mpg city / hwy? - from above, I assumed you were talking about towing
5 - Any other observations you've made good or bad about moving to 4.56s? Any regrets about it?
I'm thinking 4.56s would be a pretty good match for mostly unloaded daily driving from 35 - 65 mph with stop & go traffic. Most of my hwy trips are slower than 65 anyways due to traffic.
M
mtofell
Then:
Here's a site with and RPM calculator that is pretty cool:
Differential Gear Ratio Calculator | West Coast Differentials
It's been a few months since I looked into it but I seem to remember on the highway it was like losing 6th gear and having 5th as the top. Maybe a 400 rpm difference. Not too bad until you're going over 75-80ish.
The people I've read about going from 3.73 to 4.56 are super happy with it.
I'm especially interest in hearing about #2 - the shift points.
pytbul
Utah
A few questions about your gear swap... * first, are you on stock tires or larger than stock (what size)? Truck is bone stock except for gears.
Then:
1 - What are your rpms at 65, 70, 75 mph?The following chart lists the RPMs your engine will be turning while driving at a given speed.
Road RPMs at given speed in miles per hour
65 70 75
1 9701
2 5496 5919 6342
3 4235 4560 4886
4 3003 3234 3465
5 2433 2620 2807
6 1862 2005 2149
R 13335 14361 15386
2 - Did the gears make a big difference on daily drivability with the trans shift points? Really helped with the 1 to 2 shift while loaded. tightened the shift points up across the board.
3 - How is it at holding speed on the hwy (65 - 75 mph)? Much nicer holds gears longer
4 - Any increase / decrease in mpg city / hwy? - from above, I assumed you were talking about towing. slight increase when towing. didn't notice any loss in day to day
5 - Any other observations you've made good or bad about moving to 4.56s? Any regrets about it? love the results. only regret is slight gear whine. But you really have to listen for it.
I'm thinking 4.56s would be a pretty good match for mostly unloaded daily driving from 35 - 65 mph with stop & go traffic. Most of my hwy trips are slower than 65 anyways due to traffic.[/QUOTE
Overall i am really happy with the change in performance and driveability when towing the fifth wheel or with just the slide in camper. Only problem I have is when empty. I just can't keep my foot off of the skinny pedal.
14RAM4X4
2015 RAM 2500 4x4
6.4L Hemi
:roflsquared: Thanks for the info. I was pretty sure this was the direction I wanted to go. And now I will start saving my pennies. Hopefully next summer I can move to 4.56s.
I can live with a little gear whine. I hardly heard anything above the hum/roar of my MTs at hwy speed. Nothing the volume control won't take care of.
wrtaylo
ECM / Programming Change
Howdy,
I am new to the forum, I have been following this thread. I went to my local 4x4 shop yesterday, and was about to pull the trigger on the 4.56 swap. However, they brought up several questions that spooked me......
Do I need to do any programming change with the gear swap (they were worried about the ECM kicking the truck into limp mode) - I did not think so, but I wanted to hear from others that have done the change to a 2015.
Speedometer calibration - does it throw off your displayed speed (maintaining stock wheels)
I live in SC, so we have rollers for the day to day, and then decent pulls up to the smokey mountains. The 3.73 has caused the truck to lug significantly pulling a 6500# load.
Thanks all for the help / advice. Sorry for the first time post asking tons of questions!
DannyMK2
Long Island, NY
2015 Power Wagon
Howdy,
no and no. gear swap requires no programming whatsoever. only thing that is going to affect the speedo is a change in tire size.
brandonjansen
Exactly what DannyMK2 said above. No need for programming change and it definitely won't go into limp mode and the speedometer won't be affected at all as the newer Ram's read them off the wheel speed sensors, not the transmission output shaft.
wrtaylo
Thanks
Thanks for the info! I plan to get the gears ordered this week, looks like an approx 2 week back log at the shop. I will post up the results.
Thanks again!
RAM_Designs
Rockwall, TX
6.4L Hemi
I need some 4.56's myself, these 37's are making me a little too sluggish. Let us know how it goes, I'm sure you'll get yours done before I decide to order anything.
M
mtofell
Thanks again!
Keep us posted... in particular I'm interested to know how the parts ordering goes. I've read there can be some confusion, especially on the front diff. Where are you ordering from?
wrtaylo
Will do. Clemson 4x4 is handling everything.
Looking forward to the better drive ability. Riding through the mountains yesterday it was running through the gears, could not find a happy place.
wrtaylo
Not so good news.....
After the initial quote of 1800....after specing out everything, the quote came in at 2700. The guys at the shop spent all day calling around trying to get the price down. Looks like the gears were not the issue, it was the dress kit ( bearings,set) that were approx 500 an axle.
So I held off. That is getting way too close to trade in territory. I had a less than 2k threshold in my mind.......
They are going to call around some more this week, and see if they can find anything else.
Crap
Agcat
