6.4 Hemi Gear Swap
SuperBeeMike
Sparks, Nevada
4:56 Gear Swap Update:
I went out over the weekend with the trailer and I must say, the new gears are really helping the Hemi out. I noticed a few improvements and I wanted to report back.
I went from Reno to Yerington, Nevada, for Night in the Country. Nevada opened a new state route (USA Parkway), and it has some decent grades to pass. I had taken this route before when I had the 3:73's and the truck would struggle on the big pass, down to 35-40mph, bogging 2nd gear. This time, same hill with 4:56's, and I was in 3rd, pushing 50-55 mph, and if I remember right, in the 4k RPM range. I also want to say from a stop, the truck is more motivated to get things rolling now. Another thing to note was my RPM in tow haul mode. Since 6th is locked out, I'm running down the interstate in 5th gear. At 65mph, I'm right round 2500 RPM, and the truck seems to like it. With that, I noticed my gas mileage is up around 1 mpg on this trip, maybe a little more.
Overall I'm am very happy with my truck. It still doesn't pull like a Cummins but it is very competitive now. While going out to Yerington, I got stuck behind some POS VW bus. while going up hill at 40mph. I was able to safely pass the VW, getting up past 70mph before I merged back in. Best part was there was an old 7.3 Superduty Ford behind me, towing a similar sized trailer. We both pulled out to pass and when I merged back in, I had a lot of distance gained between us. Now, not sure if he was maxed out but it was nice to not be holding anyone up out there.
So bottom line, I highly recommend gearing up these truck (Ram, I hope you are listening). 4:56's are the magic combination for stock height, stock tire trucks. Would 4:88's be better, I would say for me, no. highway RPM would be getting up there, more so in Tow/Haul Mode. While being a bit pricey, I find myself much more relaxed, and less stressed, while traveling. That alone is worth the investment to me. I won't ever recoup the cost in fuel mileage but maybe my transmission will last longer, or my engine, or my heart, its hard to say.
Happy Towing - Mike
busterbrown
Detroit, MI
2017 Ram 2500 Megacab Laramie
Happy Towing - Mike
Thanks for the update. Something I may look to do in the near future.
14RAM4X4
Sweating somewhere in South Texas
2015 RAM 2500 4x4
6.4L Hemi
So is everyone going with AAM gear sets?
I was looking at Nitro Gears from Just Diffs. They have the front & Rear RP sets with master install kits for $1,325.00 / GPRAM2500. These are the gears I was planning on buying. Labor on the last 2 gear installs was about $900 ~ $1100. So I'm hoping to be in the $2500 range.
found them here: http://www.justdifferentials.com/GPRAM2500-SELECT-p/gpram2500-select.htm
The only note I see on that page states a ring gear spacer is needed for aftermarket locking diffs.
SuperBeeMike
Sparks, Nevada
My shop supplied AAM gears, a new front carrier, and charged me just over $2700. They did reuse some of the bearings since my truck only had 3,500 miles on it. I wanted factory gears as I am pulling quite often and didn't want any issues. Not that Nitro is bad, but I figured AAM would be best. The shop I used recommended the AAM gears too. So far they are trouble free and quiet.
reloaderguy
Oregon
2016 Power Wagon
That depends on the ratio you select. I am running AAM Chrysler rear gears and Yukon fronts. Since there isn't a AAM Chrsyler 9.25 5.13 option I went with aftermarket. There is a AAM GM factory option but I didn't feel like the added cost was warranted since GM 9.25 gears are not a factory gear in a Ram solid axle.
Some ratios there are only rears available, such as 4.88 (if you can find them). If you can get AAM that is probably best, however, there are plenty of good aftermarket gears too. The priority should be matching the ratio to the tire size you run now or possibly run in the future. Also, the transmission gearing is so high that you can't possibly go too low (within reason). My opinion, based on my own gearing selection, take whatever ratio you're considering and go one size lower.
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
Hi Mike,
Good update, thanks. Did you find out in your research if the mopar/aam 4.44 gears could utilize the original front carrier? That would save some cost if possible. Glad you like your new gears!
SuperBeeMike
Sparks, Nevada
Hi Mike,
I did not look too far into the 4:44's. After seeing posts about engine RPM's in relation to the different gear ratios, I was actually comparing 4:88's to 4:56's. I knew if I went too far with gears, I could step up to 35" tires to compensate. If I didn't go enough, I would be stuck living with regret. I was nervous on the 4:88's because the pinion gear loses surface area where it contacts the ring gear. I felt the 4:56's would be a bit stronger.
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
Ok, sounds good. Thanks!
Don_T
Does anyone know of a place that can be trusted in northern Vermont to do gear swaps? I am thinking about going to 4.56 or 4.88 in my truck.
theviking
With all the mud bogging and truck pulling up your way you'd think it would be easy to find a shop there.
RAM_Designs
Rockwall, TX
6.4L Hemi
I'm running 5.13s with 37's. If you plan on sticking with 37's then 5.13s feel good. 5.38 would be better for 40's.
What are your rpm's with the 5.13's? I'm running 37's on a 2016 as well, and I can't seem to find reliable info on rpm's, even with calcs. Everything seem to conflict.
Reactions: U&A
U&A
2016 3500 SRW
6.4 HEMI
http://www.csgnetwork.com/multirpmcalc.html
Have you tried this one. Seems to be very accurate. Use the very bottom calculator....
Input ring gear ratio
Tire hight
MPH
Final trans drive ratio
The picture shows final drive ratios.
reloaderguy
Oregon
2016 Power Wagon
2k RPMs at 70mph. I would never considered 4.56 gears in a 14+ Hemi with 35s or 37s.
Reactions: U&A
reloaderguy
Oregon
2016 Power Wagon
U&A
2016 3500 SRW
6.4 HEMI
Thanks for the link
The Calculator you linked definitely is a good one. The one I linked and the one you linked come up with identical numbers, I checked.
If you’re looking for more complex calculator that includes under drives and transfer cases than yours is the one to use.
If you’re just looking for simple one for a 4 x 4 or 2 x 4 truck to find RPMs with a given speed the one i linked is simpler.
JMO
reloaderguy
Oregon
2016 Power Wagon
Thanks for the link
JMO
The math is technically the same but I linked to a page that will auto populate transmission ratios and give you comparative tables for multiple final drive ratios in every gear for user specified speeds.
U&A
2016 3500 SRW
6.4 HEMI
Ok
Fatboy1989
