amurp15
I know @diymirage just posted an almost identical issue, but it seems like he's going the upgrade route, and I would like the 'fix this as cheaply as possible route'.
I have a 2016 2500 6.4 with 205k miles. Engine light came on one day, cylinder 4 misfire, rougher than usual idle (nothing crazy), a couple of instances right after startup of a nasty ticking, but otherwise normal operation. I took it upon myself to swap spark plugs, coil, and fuel injector with cylinder 2, same issues, same codes. Took it to the shop to have them pull the valve cover, and they tell me the pushrod in cylinder 4 is bent and sent me some pictures. I used to be a dealership mechanic, but I've never done any internal engine work, so maybe this is my untrained eye, but I can't see what they're talking about. I'll throw the pictures down at the bottom to see if you guys can spot it.
Anyway, they said an engine replacement would be cheaper than replacing just the valve, because the engine has to come out of the truck to replace the pushrods. Do you seriously have to pull the whole engine out to pull off the cylinder head? The passenger side head, which is the one with the misfire, seems pretty spacious around that side of the engine bay, like you could remove the head while its still in the truck, but again, I don't know anything about this kind of stuff. So for now, I'm just driving around with the bent valve, hoping it doesn't blow out the side of the engine. Kind of lost on what to do next, $15k seems a little steep for one busted valve.
Any past experience, tips, and tricks are always welcome. Thanks in advance.
