6inch speed demon led lightbars
zachary.vv
So i got given a set of 6 inch lightbars from speed demon with a wiring harness. Now i need to find somewhere to mount them on my truck.
I was thinking i would put them where the factory fog lights would go? Or other option was behind the grill?
Do you guys have any ideas?
Sent from my SM-G930W8 using Tapatalk
quietpeen
2021 TRX
Hellcat
Where you are thinking the factory fog lights would go is actually where the factory tow hooks would go. I've seen people mount them there
Z
zachary.vv
Hahah yeah the tow hook area.. funny i actually just asumed it was for the fogs
Z
zachary.vv
I tried to find somewhere to get information on how to remove the bumper but couldnt find anything
quietpeen
2021 TRX
Hellcat
That is a great place to mount them though. I don't think you need to remove the bumper to mount them there
Z
zachary.vv
Ok but how do i mount them any ideas?
Z
zachary.vv
They seem to have side mounts
Z
zachary.vv
No one can give a guy any insight?
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
I will hopefully be mounting a similar eBay set in the tow hook spots on kit SLT within the next week or so.
I took a look behind/undet the bumper, and the plastic blanking plates are held in with 4 10mm bolts from the back. Take those out, then slide/wiggle the blank out towards the middle. Then you will have to look for a spot to bolt down the light mounts.
Mine have a single bolt/mount point vs 2 which should make it easier for me. First I need to build a harness for them.
M² Mods - From my non Flammable S7!
Z
zachary.vv
That sounds great. Do you know how far of the bumper it would sit attached to that upport behind there?
Z
zachary.vv
Im really not sure how to get this going here if anyone out there has done leds inplace of the factory front tow hooks let me know.
sticknstring
Perfect size to mount out back and wire into your reverse lights. That's what I'd do with em.
Z
zachary.vv
Your saying use them both out back of thw truck for lighting the box? Or just as reverse lights?
Demon-HeMi
Houston
2003, 2003, 2008, & 2013
(2) 5.7 HEMI, 3.7, & 3.6
Toyed with this idea...
Each has about the same output as a LED pod
flush mounted LEDs in the tow hook area
Z
zachary.vv
That looks legit. Hmm i need to figure out how i can mount mine like that. They have these big side mounts noy ideal for this situation.
Demon-HeMi
Houston
Guy i know did this, made his own brackets that are welded to the sub frame behind the bumper
Z
zachary.vv
Your great help! Thanks for a pictute of how it would look. Now i just need to figure out mounting
sticknstring
I'd flush mount them both in the rear bumper. If you do a lot of backing up to trailers in the dark like me.
Mpgrimm2
SC
5.7L
I wouldn't mind seeing a link to those 6" strips in the tow hook blanks you used. Are they adjustable/aimable?
Here's how I installed mine on a 2013 1500 ...
Pt1f351600a76cb52ef30765706c33b49eb.jpg495220dc6141dba428075ee5ed30ebcf.jpg08c36914dd5360de640f4bcd7de8ffdf.jpg4e09cd02e9da403ea0c64527e1f41ce7.jpg
Got the 4"x 36" slotted 14ga plate/strap from Ace Hardware, cut it to 13.5", painted it, and mounted it using 2 clips and bolts from the tow hook blanks...
Mpgrimm2
SC
5.7L
Part 2
20c116bb328022fe7d06e9543f86d4ad.jpgb445d55ba05760af6baff7c30ea3ead5.jpg3820ba99e4f082c80ff24331932abdd7.jpg0d347e4040fba68586bf50bd95a3842f.jpg
Ed11
