Greenham
I was looking to add some extra backup lights, and a tailgate light.. "The type of light that goes under the tailgate and has, Brake, Running, Turn and Back up lights."
As you may know they usually come with a 4 pin flat connector BUT NO REVERSE.. It say you have to pull the back up light from somewhere else...
I have a 7 pin (big round) trailer connector on my rear bumper. I didn't want a bunch of unsightly wires going from the outside of the rear bumper to the inside..
I set out to find an answer at Amazon... This is what I came up with
I found this Y harness. It's used to extend the 7 pin for use with a 5th wheel trailer. It is a Y that plugs into the harness under the truck on one end and back into the outlet on the other but it also has all the wires you need to plug into the junction box below.
Y Harness:
https://www.amazon.com/gp/product/B000GAO1HC/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
I mounted this up under the bed behind the rear drivers wheel. It's weather resistant, somes with various knockouts and plugs and even has the the color coded wire pins labeled. It's less then $10
This is the 7 pin wire box
https://www.amazon.com/gp/product/B07X1WTKSP/ref=ppx_yo_dt_b_asin_title_o07_s01?ie=UTF8&psc=1
I put the reverse lights in and tied them in the box. Works like a champ. Even if you want to turn them on with a seperate light you just need to run a power lead from your switch to hot side of the box. The lights are grounded in the box.
Now all the other lights are easily added under this cover.
I hope this help someone else who was looking for a more elegant way to add lights to your truck
Y Harness:
