74 yrs old 5th dodge truck owned. Having front drivers brake locking , replace caliper,pads and rotor, still locks? Any ideas ? 2006,2500,4wd.
Don Greene 84
Brevard,n.c.
74 yrs old 5th dodge truck, have front drivers side break locking, they changed rotor,caliper and pads, still locking? Any ideas ?
crazykid1994
Brake line or abs module. I’d change the brake line first though obviously.
RamRod37
2014 Ram 2500 HD 5.7 Hemi
Georgetown TN
I second this post seen many over the years working on vehicles the rubber brake line that goes to caliper the inside liner comes loose acting like check valves the foot pressure forces fluid past it to activate brakes but the line closes off not letting pressure back off brake pads. That would be my first thing to replace they got so bad we made it standard when changing calipers to always replace that line. start there good chance that's the issue its the easiest and cheapest the abs modules are not cheep buy any means and locations of some can be a SOB to replace plus age lines rust and then that becomes a PITA all on it's own
Gregf
