Ok so I just got my dodge and came over from a powerstroke. So far so good I love my 16 cc lb tradesman. But I have a annoying grinding/ vibration at freeway speed. Truck runs fine, but this sound is annoying, comes on and off as I feather the throttle, it’s pretty loud. Could it be lift related? Driveshaft? Any help would be awsome thanks
While I work on fighter jets, these type of 'write ups' are so hard to diagnose. Pilots would tell us, he had a vibration in his feet, at 360kts, at a 45 degree left turn, at 24500'. Really? You want me to figure that out.
Your issue too has so many things. Let's make a list, IMO most possible to least.
- U joints
- Tires worn or out of balance
- Worn brakes, the tab that squeals, telling you it's time for new brake pads/shoes
- Bad brake caliper - one could be grabbing, not releasing like it should.
- Warped rotor, drum
- Front end, tie rods, etc
- Drive shaft out of balance
- Warped wheel/rim
- - Bad transmission (not likely), but it's possible.
These are what come to mind, initially. The first two are inexpensive to fix. Getting these first two fixed are good maintenance practice.
There are many very smart people on the forum...
Let me know, I'm really happy to help with this with you.
