Thoughts on my new 2022 1500 Classic
HunterCat
Central NJ
3.6 V6
Hi All. I just bought a 2022 1500 Classic that I ordered as a factory build. Thought I’d share my experience and thoughts about the truck. While I was waiting for my truck, I did a lot of reading on this forum so I wanted to add a little back.
First of all, some may be interested to know that I took delivery of my truck exactly 1 month and 1 day from the date of order. I was expecting to wait around 6 to 8 weeks but I was pleasantly surprised. The dealer was surprised as well. I did buy a somewhat base truck so that may have helped. It’s a Tradesman RCLB RWD V6. I was replacing a 2007 RAM 1500 RCLB RWD 4.7 that I had bought in 2015 as a second vehicle. I quickly fell in love with it and it became my DD. Unfortunately, its latest problem wasn’t easily remedied and I gave up on it. It had around 160K miles when I bought it and I gave it up at 220K. Besides the engine and alternator, everything in the truck had been replaced at one time or another. I have no idea how the truck was cared for prior so I can’t really fault RAM.
When it came time to find a replacement, my first preference would have been Toyota. However, the 2022 is a complete redesign with a newly introduced (for Tundra) 6 cyl twin turbo engine. I don’t buy the first 2 years of a new design and I don’t like turbos at all. So, Toyota was out. GM, Ford and Nissan were never in the running (had a really bad experience with a Silverado and I just don’t like Ford and Nissan). Also, I wanted a regular cab so RAM Classic it was.
Obviously, the RAM is brand new but I’m impressed thus far with the build quality and design. It’s a couple hundred pounds lighter than the old truck but it feels substantially heavier. I guess that’s good and bad. Good in that everything is much tighter and it feels like a tank but I really prefer the feel of the old truck. It felt much more nimble and maneuverable; the steering was MUCH lighter and the engine felt more responsive.
So far, the V6 seems adequate but that’s about it. The HEMI was just too much engine for me and I didn’t want the drama associated with it. I don’t tow but I do fill the bed to capacity on occasion. I do wish that they still offered a smaller V8 option between the two engines. Around town, the V6 is fine and the gas mileage is impressive so far. On the highway, the V6 shows it’s lack of power. As an example, cruising around 60 and getting up to 70 involves some drama. I’m accustomed to just giving a little gas and having the speed rise steadily in the same gear. In order to accomplish this with the V6, you need to really put your foot down to get anything to happen. I’m not sure how people in hilly terrain get along with this engine. Keep in mind also that my truck configuration is among the lightest.
I didn’t get 4WD because I have a second vehicle that has AWD that’s great in the snow. I’m in central NJ so snow is not a major concern and the worst this truck will ever see is the occasional dirt/gravel road. I did get the LSD so I’ll see how that works out. I think the old truck had LSD and I would shovel a bunch of snow over the rear wheels and it did fine for my area.
So far, my only minor gripe is the clock or lack thereof. How does a work truck not have a dedicated clock? In order for the time to appear on the screen, the radio has to be on. No radio, no screen. I typically don’t drive with the radio on. So, for me to get a clock in the cab, I have to mute the radio and make a screen selection. When I restart the truck, it does not save this preference. The volume on the radio is restored and it defaults to the radio page. I have to hit the mute button and select a different screen on every startup. Very annoying.
Last random thought about Active Grill Shutters: I wasn’t sure if my truck was going to come equipped with them but it did. I was sure, based on what I’ve read here, that I would remove most of the slats. I’m going to leave them for now and keep an eye on the temps. I’m wondering if they changed the operation of the shutters. Mine close and open once on startup to test and then remain open during warmup. This morning, it was in the high 50’s and they remained open. Perhaps it’s not cold enough out yet. So far, I noticed that the coolant temp stays between 199-203F while on the road which seems fine. When idling or backing down my driveway it will climb past that but I doubt removing the shutters will help in that limited scenario. I think the highest I’ve seen is 213F.
star_deceiver
Airdrie, Alberta
3.6 Pentastar
How we get around in the mountains? Simple, push the go pedal down. If you want things to happen quickly you need to push the gas down far enough to get the transmission to downshift into 3rd with at least 4000rpm. You will not hurt this thing with rpm, but watch your coolant/oil temps if you hold 5000+ for a long period of time.
farout75
Laurie, MO
5.7 L
DO NOT REMOVER THE SHUTTERS! This will void your factory warranty. I've had two RAM 3.6 trucks. The mpg was pretty good, but my huge issue was lack of torque. It was pretty quick, but going up steeper freeway hills in Missouri I had to change the gear selector to 6th to keep up with traffic. After having the 5.7 now I doubt I would ever aging select the 3.6. Be aware the 3.6 is not without it's potential issues as well. Oil changes are a critical issue and changing at no more that 6,000 mile is a wise choice. Clad you like and enjoy your RAM!
CamperMike
Peoria, IL
I would not be so sure you need constant oil changes. My previous vehicle was a town and country with the 3.6. I towed a popup camper weighing nearly 3000lbs with it often. I followed the dummy light which meant around 8k oci. The engine ran perfect and used no oil when I sold it with 150k miles.
Jeepwalker
WI
2012 Reg Cab, 4x4
Nice write-up and review. Thanks! Always love to hear the reasoning why someone ended up with their vehicle over another one. Only thing is ...you forgot a picture of this nice machine!
I haven't driven a 3.6 so I can't say. Are you able to easily kick it out of 8th gear and gain some acceleration torque that way? One thing I would recommend is get it rust-proofed (undercoated...or whatever you call it out there). These 4th gens DO rust. And they look terrible when they do. The rear wheelwells DO collect and hold rocks/dirt/debris. That's the genesis of the rusting. The time to do that is right away. Esp since you tend to hold on to your trucks for a while. Not that expensive if you do it right away. And the inside of the rockers and cab corners too. Front Fenders and tailgate. My neighbor's 4th gen has been rusting away before my eyes. All the places I just listed.
Oh, on the clock, just type in car/truck clock in ebay or Amazon, and there are a lot of choices. And if you want an LED 12V one, ..just type that in. A good 12V LED clock tied into your ignition, you won't have to change batteries.
H
HunterCat
Central NJ
3.6 V6
I think you touched on part of my problem; I have an aversion to high RPMs from years of owning vehicles that didn't require it (plus I'm very light on the pedal). It's probably outdated thinking but when the needle starts getting up there, I cringe. A V6 with an 8 speed is naturally going to spin so I just have to get accustomed to how this truck operates.
H
HunterCat
Central NJ
3.6 V6
I'm happy with the temps thus far so the shutters are staying put. As I mentioned, the temps are mainly staying between 199F and 203F which I think is fine.
I'm pleased with the MPG thus far and it should only get better since I'm just at 500 miles. Last couple of days, I did a bunch of highway mixed with some in town driving and the computer is telling me 24.1mpg.
H
HunterCat
Central NJ
3.6 V6
I forgot to post pics! Don't have much yet but here's one sans badging (could they make the badging any bigger? :) ). And another with the old girl in the forefront (I miss that truck even with a brand new one in the driveway).
Funny you should mention rustproofing. Just had it undercoated with FluidFilm @ 400miles. My old girl was in pretty good shape but was starting to develop rust in the rear wheel wells and light rusting underneath. Seems like every older RAM in my area has it. I plan on using FluidFilm every fall to eliminate the issue.
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
So what are the shutters supposed to do exactly? Are they there for aerodynamics or cooling?
Jeepwalker
WI
2012 Reg Cab, 4x4
Truck looks good!
Regular fluid film in the rears is probably not a bad idea. Eventually dirt/dust/rocks will fill in around the wheel wells in the image below (red area) where it's spot welded to the bed side. An agent that get in there and also helps prevent rust, should help extend things. It would be helpfull if they made it drain better, but then guys wouldn't need to buy new trucks as quick!!! Here's what the inner wheel well looks like.
