8.4 Uconnect/Bluetooth from 3" W/O Bluetooth
Redheadhunter21
SFL
I have a 2018 Ram 2500 tradesman with the 3" radio with no Bluetooth/Uconnect function. It seems most people that have swapped to the RA3/RA4 have gone from either a 3" uconnect or 5".
So my question is the Bluetooth module a separate part or incorporated into the head-unit. I found the module for 2012 and older but cant find anything for a 13+.
From what I have researched I need steering wheels controls and mic too.
JOHRY
Ontario, Canada
EcoDiesel 3.0
Bluetooth is part of the radio itself. The functionality is there by default. You just need a mirror with mics for the handsfree to work (you can still connect and play music without that part)
justintaylor
Barrie Ontario Canada
3.6L
Exactly what JOHRY said.
most auto wreckers ave the mirror assembly for a half decent price. just dont forget any wire harness running down the a pillar if you want to do the swap
R
Redheadhunter21
SFL
Thanks again, I'm trying to keep my stock mirror as I guess Im the only person that would rather have my backup cam up their instead of the head unit. Its been a rough going however trying to get a part number for the 2018 style mic that mounts to the headliner vs mirror.
R
Redheadhunter21
SFL
As much as I didn't want to, I ended up going with the infotainment Mic. For now I have it mounted on top of the bezel just on the driver side of the little cubby.
The Bluetooth works great too, that alone was the reason to upgrade
