- Joined
- Aug 5, 2016
- Posts
- 335
- Reaction score
- 169
- Ram Year
- 2018
- Engine
- I-6
hmmm I don't remember such drain plug (could have missed it). when i did my change, I emptied the pan via removing the trans pan bolts and dropping it into the drain pan. But what does the drain plug have anything to do fill plug? If your adding fluid, its the procedure to fill it up with X quarts, start the engine, get up to temp, remove the plug and wait for it to dribble out. Either way, the amount of level you see on the scale is not feet of difference, its inches at most. If someone cannot see a level vehicle then I guess they need to do fluid level checks.
