8 speed swap
Do you have an OE tune file read from HP Tuners?
My tuner would have the stock file on his laptop,and we haven't transferred the stock tune to my laptop yet.If you want to read the tune file,i'm in Alberta and you can come plug into the car and read it if you want.Sending a file is beyond my paygrade.
Sami932
Dubai
I am writing it up as we speak as i just did the swap on my 2014 in my driveway at my apartment garage with basic hand tools, a jack and all the OEM parts needed to do it.
Did you manage write it up?
t0ymach1n3
Dallas, TX
5.7L???
Still working on it. Life has not been kind to me the past two months and I have about a 1/3 of it written up so far. I also didn't take a lot of pictures being I did it all by myself at my apartment garage. I'm hoping to get some stability going and sit down and just knock it out.
In the meantime, if you got any questions at all, feel free to ask me and i'm happy to pass along what knowledge I have.
t0ymach1n3
Dallas, TX
5.7L???
Just wanted to give a quick update to everyone:
Want to start with thank you. It was this site that gave me so many ideas that brought the youthfulness in me out. Over the past year this place has helped me change my 100% bone stock 2014 Ram 1500 Express to something I could have only dreamed about. I can't express enough my gratitude to everyone, no matter if we are cool or could have had some disagreement. Thank you for helping me to live my dream and I hope to help you live a bit of yours. Or at least help ya fix something lol. Now to the really important stuff.
I am still on the fence on how to publish this work. It has been suggested to me to paywall it or even actually publish a book on it. I can't, in all good conscience, do that to a place that freely gave me information and assistance with no thought of getting paid for it and neither will I. Plan is to start a new thread and put everything there. I have about half of the steps written out and do not have many, if any, pictures of the actual project process. I am doing my best to try and take pictures and deep explanations of the more difficult points to this past just basic swapping of the trans and the harnesses. I will also be doing my best to include the needed steps for the things that needed to be done in AlfaOBD to make everything happy and working. That part will come after the guide is published.
I want to say one other thing before I put out anything. I am not a mechanic. I have never worked for anyone that does this kind of stuff for a living. I am just a good ol boy from a small town in Oklahoma that enjoys tinkering and figuring out how things work. I'm in the IT field and sit at a desk most of the time and do this for fun more than anything. This is a guide, a story if you will, of what I did and what I experienced and what I was able to accomplish and wish I'd had known before hand. I take no responsibility for anything you do, break, brick or destroy in the process. I will 100% answer any questions anyone has about it and give my opinion. I will always help out anyone that needs it. Just wanted to get this out there so there is no confusion as to what this is and my responsibility to taking on a project such as this and your outcome versus mine. Thank you again!
jawzs2
South Jersey
Looking forward to your write up, I've been toying with the idea of doing this with mine
DILLIGAF
Canada
from Sound German Automotive FB post
So I have been fielding a lot of questions about 8 speed swaps on 2013 and newer Rams. Hopefully this will get shared among the appropriate groups out there and reduce the amount of calls and emails to me about this. My products are not needed for 2013 and newer Rams. Just copy what Dodge did with wiring and programming on the factory 8 speed. Dodge made this truck so you just need to wire up the transmission and shifter and reprogram/replace the ECU and BCM. BCM can be done with Alpha OBD and ECU is just a factory 8 speed ECU file. This can be done for 1500 and 2500. If you have a 6.4 it looks like the 2019 up 2500 with 6.4 will work. I have only ever looked at the 2019 file personally but this looks solid to work. And you can see on the diagram here. The shifter and TCM are really minimal wiring. Power ground/ Switch power, CAN_C and dedicated CAN directly from the shifter to the TCM. I can program ecus with just about any file needed but I recommend that you just get a used ECU from an 8 speed truck and change the vin. Then you have your old one reprogrammed later for a spare if you want. This is it. It is pretty easy to do and you can see it is about 13-14 wires total.
If you want the console shifter with manual mode then you will need a Charger/challenger TCM calibration in the transmission. The Ram calibration will not work. You will loose tap+- on the steering wheel though. Also the BCM will need to be coded for this shifter instead of the Dial shifter. I can flash TCMs if you need this. I have 5.7/6.4 files for most model years of challenger/charger. A couple of the GC files as well.
Hopefully this helps.
HemiLonestar
MD
Saw that yesterday....again, so easy for the 4th gen guys lol.
