85mm TB install (pics)
jojo750
south carolina
v6
installed MOE's 85mm ported throttle body today. took about 10min to install. my truck is a 2011 big horn, quad cab with 5.7hemi. 18k miles...
here is my short write up on installation.
removed negative terminal to battery.
removed my vararam to get access to throttle body.
immediately noticed the buildup on inside of throttle body. you can see where i swiped my finger across the middle.
unplug wire harness to throttle body.
remove 4 bolts that connect throttle body (8mm).
remove throttle body.
compare stock vs. 85mm. notice buildup on bottom of the throttle body!!
install MOE's 85mm throttle body. reinstall 4 bolts ***(BE CAREFUL TO NOT OVERTIGHTEN THOSE BOLTS!!! they are screwing into plastic, and can strip farely easily.) reconnect wire harness to throttle body.
reinstall vararam and reconnect negative terminal to battery.
jojo750
jojo750
south carolina
v6
forgot to mention.
i do NOT have a catch can, hence the buildup on the TB.
but hopefully i will have one by next weekend, if moe's gets their backorder.
i will take pics of that install too.
jimdd810
Inspired me to do the mod! Awesome right up
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Great pics and write up. Catch cans will be shipping around the middle of next week. That side by side picture of the 2 TB's shows just how important the catch cans are.
ATXHEMI
Round Rock Tx
It looks like the shaft is more centered on the new tb. Are the new ported tb's half shaft?
jdichiara
NY
Thank you for the write up, this makes me feel much more comfortable to do this mod myself.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
The TB's still use the stock shaft. Its just the angle throwing it off.
joeshemi
orlando,fl
i just clean my tb every couple of weeks,takes 5 minutes.Man that thing was dirty jojo750,i'll bet even if you just cleaned that thing it would have felt like a new truck after it was cleaned.Glad to see you like your new tb,looks awesome.
chuck
Maryland
2013 True Blue Big Horn
Thanks for the write up on this! I was just searching the forums for this exact topic. You da man!
jojo750
jojo750
south carolina
v6
unfortunately, tb cleaning isnt on my list of maintenance. never thought id have to clean one. probably never will anyways.
once i get my catch can, im never going to look down there again until i trade my truck in, and put the stock TB and air filter back on.
Valth
Odessa, TX
Nice install man. I cant wait to get some more money up, I got a moes TB and BT catch can next on my wishlist. Thanks for the write up.
jojo750
jojo750
south carolina
v6
no problem.
the install was as easy as it looks in the pics.
i did the BT catch can today. lo and behold, it was just as easy.
no pics of that install though.
Lhemi
OKC OK
6.7 Cummins Turbo & Hemi 5.7
How much HP did you gain?
jojo750
jojo750
south carolina
v6
dont know. no access to a dyno locally.
but dont know if you'd notice ~10hp anyways.
TXCMark
Houston
5.7L
I installed my Moe's TB last week. I agree, 10 hp is hard to notice on these trucks, but throttle response is much better. My diablo arrives tomorrow from hemifever; cant wait to install the tune and take more advantage out of the extra air flow from the TB
Bombdigitty
Is there a gasket that should be replaced? Or is it like a rubber seal that could be re-used?
noraa73
