89 D100 5.2 magnum swap got a trans question?
BabyRayD100
ATL
3.9L v6
My truck is a 1989 D100 3.9 v6 2wd auto i bought a running and driving 1998 durango with a 5.2 v8 4x4
i already pulled the motor and im getting ready to send it off to the machine shop i plan to keep the fuel injection hence why i bought the entire truck so i have the computers and wire harnessing
i done research and i think the trans in the durango is the 46re?
so whats my best option can i install the 46re and not hook up the front driveshaft to the transfer case or should i just sell that trans and pick up a 2wd 46re?
i have not pull the trans out yet but when i was searching transmission on ebay i saw a 2wd tail shaft for a 46re. Is it possible to swap that onto my 4x4 46re transmission?
or will finding a 46rh be better since my current trans is a 32rh i believe
crazzywolfie
under the truck
a 46rh would be nice if you do come accross it but you can swap out the overdrive assembly on the 46RE to make it into a 2wd transmission. it is about the only real difference between the 2wd and 4x4's. just the overdrive assembly.
crazzywolfie
under the truck
that is just a housing no guts. i don't know if the internals would be the same on the 2wd as a 4x4. i have a feeling the output shaft on a 4x4 is different but not sure.
shift linkage should be pretty easy to make work. just have to used the magnums kickdown cable setup
B
BabyRayD100
ATL
3.9L v6
ok my best option would be to just buy a used 2wd trans and sell the 4x4 one
is looking for a 46RH still better option for me or because i have a complete wiring harness i can open my search for either the RH and the RE model?
ChloeBrooks
