Zachary Williams
Brenham Texas
Laramie Sport 5.7 hemi 4wd
ive got a 2013 1500 sport 4wd 5.7. ive replaced blower motor,resistor, relay and my a/c still will not blow. when im driving, when its not hot outside , i can feel COLD air come out of the vents but its not because of the blower. anyone have any ideas?
Thanks,
Zac
R.L.K.
Bristol , Tn.
Thanks,
Zac
You may need a new HVAC Module .
Sounds like you have the 4 speed blower ?
R.L.K.
Bristol , Tn.
There's been a few here that have experienced a failed HVAC Module ..it's located behind the passengers side air vent , to access it's plug it's best to remove the glovebox ( lower one if you have two ) you may be able to get to the plug with the glovebox installed ? I removed mine it's simple and no tools required just hands . I also pooped out the passengers side air vent , again no tools just hands .
To remove the HVAC Module open the passengers door , remove the long vertical , football shaped dash side panel to access the screws 2ea located in the keyhole slots pointed out below in the picture [emoji1360]
R.L.K.
Bristol , Tn.
Either use the vin# of your truck to order a new one or get the # off the HVAC Module itself .
R.L.K.
Bristol , Tn.
Thanks,
Zac
Assuming you are the original owner and have not upgraded the trucks radio , radio bezel or the HVAC system ?
anitamack
