A little hint for the 4.7 guys
SmokedRam
Zephyrhills, Florida
About a month or so ago, I would intermttently get a CEL for my EGR valve. Funny thing s, it would actually clear itself out and the CEL would go out on it's own shortly after it came on. Well, it came on again last week as I pulled into the driveway, I did the key dance and pulled te code, sure enough it was the EGR code. Next morning I went out...no more CEL, so..I did the key dance again...no codes.
So I said screw it and went ahead and bought the EGR valve from Advance. Got home, looked at where it was and said "no way I am doing that"...unlike the Hemi engines where the EGR valves are right in the front passenger side of the engine, ours is on the rear of the drivers side cylinder head.
So I called a mechanic buddy of mine, he said he'd do it for $40...I drive over and let him install it. He then hooked up his scanner to pull any codes, which none came up and he went ahead and reset the computer anyway. Took him about an hour to do, between us BSing while he done it.
Even though there were no codes, it's amazing the difference in acceleration and idle this engine has now. Definately noticeable.
Anyway, from what I have read, these EGR valves have a tendancy to fail or at least start failing between 45K and 60K miles...so, if you have a rough idle or slow acceleration, and you're still on your factory EGR valve, make sure you pay it a little attention.
inktoxicated
nj
can u take a pic of what it looks like and sorta where it is. i like buying cheap parts and changing them for ***** and giggles even if im not expereinces issues. after seeing ur freind do it, do u think u could have done it urself?
SmokedRam
SmokedRam
Sure, I can take a pic of it...and where it is. I'll do it tomorrow for you all. After seeing him do it, yeah, I'd probably give it a try.
Deviate
St. Augustine, FL
2005 4x2
My EGR was replaced within the first 20k or so mile on my truck. I have 95k+ now. Might be worth looking into...
inktoxicated
nj
wheres that pic.? autozone has one for 95.00 seems a little high rocks got it for 60
SmokedRam
SmokedRam
Sorry guys I forgot about the pic...but heres one I found on Google...
intoxicated, mine only cost $39 at Advance, then I used a coupon code to take another $9 off of it...So I only paid $30 for it.
redram2007
Colorado Springs (Ft Carson)
Im about to do the 08 intake swap, is it a PITA to get to? What did you have to remove to get to it? I also have been told i need an 08 egr valve when installing the 08 manifold but after getting the used egr from the truck the 08 intake manifold came off of i noticed they looked very different. Was the old gasket hard to clean up?
inktoxicated
nj
the one i saw at autozone looked diffirent then the mopar but the mounting points and electrical conneticion were the same. it had a black canister on top. i didnt see mine back there on my 08 ill have to look again. the one autozone had looked like this
http://partimages.genpt.com/partimages/1095857.jpg
SmokedRam
SmokedRam
Well since the 4.7 was redesigned in the 08 model year, yours might be different...the one in that pic is a PRE 08 4.7...
SmokedRam
SmokedRam
And yes, that is the throttle body, mind you the 07-older 4.7 don't utilize an electronic throttlebody like yours does.
steadly2004
Lowell, NC
CTD 6.7
I think we still have the regular throttle bodies, IIRC, just the Hemi has the electric ones.
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
redram2007
Yea i have the 07 4.7 and im installing the 08 intake manifold. But i do have the cable driven tb. I just had to buy adapters for the tb bc the 08 has 4 mounting bolts vs the 3 on ours.
inktoxicated
nj
yea my tb looks like the bottom pic. i looked again for the egr i see it but holy **** is that tooked in there. i cant even get my head that far back to the firewall to begin to see it. i hope there is some more daylight from the bottom up since im lifted maybe there som gaps. yikes. imma leave that to a pro
srtajm392
