BBartow
- Nov 18, 2013
- 5,759
- 3,395
- Location
- New Port Richey, Florida
- 1995
- 5.9L Magnum
You're fine up to 3".
I meant pick up some new stock height coils and throw the spacer on top of the new coils... my thinking is that my ones on the truck are 14 yrs old and have sagged so new stock coils and a 2.5" spacer would give me 3"s + of lift from where it currently sits now
Oh ya in that case nope nothing required. I thought you were talking 2500 coils for some reason...
And does anyone know the difference between "variable rate" coil springs and "professional" coil springs on rock auto?
Not going down the road or flexed out, but parked it should keep you at the same height. The only reason the variables don't keep you at the same height is because they give more than the constant/linear/profesional. The same way if you welded a steel bar from your axle to your frame in place of the springs, your ride height would be the the same all the time, but you would hate life while driving that truck.
duder leave them alone i did this on past 6 ram1500's i had
also ditch the swaybar too barely makes a diff
