A Little Stuck
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
So after ordering mt 2.5" leveling from RC, I did more research after which I've come to the conclusion that I want a 3-4" up front and nothing in the back with my 285/75/16's.. however if I want to return my 2.5" I will have to pay return postage which will decrease my return amount a decent amount lower than what I bought it for so I don't really want to send it back..
My questions is:does anyone know of a 1.5" lift coils or similar size coils for the front so I don't stack blocks to lift the front?
My plan is to get new longer UCA and LCA, track bar drop bracket, longer pitman arm, longer shocks and control bar drop bravket
mda8569
Vandalia Ohio
5.9 magnum
Skyjacker makes 2" coils. I think the off-road springs will give you 1.5"
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
I found skyjacker and they are a little on the expensive side compared to buying new 2500 coils... where would I be able to find coils for the off-road version of our 2 gen's?
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
Merc, whats your thoughts on putting the 2" skyjackers, 2.5" spacer, leaving the rear stock and running 33". Pre runner style? Too much?
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
Or I do have the stock coils on the truck so would you think they've compressed over time? Could I just by stock 1500 plus the 2.5" spacer and I would get 3"-3.5" of lift from where I am now? Or do the coils typically not compress over 14 years?
Merc225hp
NA
truck
gas
Oh yes they sag over time, i think you will get what you are looking for with new springs and the spacers.
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
With that thinking, would I need the pitman arm drop, track bar drop and sway bar drop bracket since it would only be 2.5" over stock but about 3" from where I am currently?
ramburger
na yer good.
axle will be a little offcenter but nothing noticable really, go with just the 2"
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
na yer good.
I just don't think only putting the 2.5" spacers on my truck will lift it enough
Johnn123
Ontario
You will most definitely need those, as well as new control arms IMO. 2.5" spacer + 2" coils = 4.5" front lift. You will effectively running a near 5" kit.
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
I meant pick up some new stock height coils and throw the spacer on top of the new coils... my thinking is that my ones on the truck are 14 yrs old and have sagged so new stock coils and a 2.5" spacer would give me 3"s + of lift from where it currently sits now
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
Any ideas how much lift I'll get with a new coil and the 2.5" spacer?
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
And would the shocks that came with the 2.5" would work correct?
Edit, after looking around and reading on other forums I've decided to leave the pitman arm, track bar and control arms stock and throw on a new stock coil with the 2.5" spacer and throw on an anti sway bar drop bracket so I don't bend it with the roughly 3" lift
MoparMagic'00
Arkansas
5.2 Magnum
May be able to flip it.. I dunno i hear of guys doing that but i dont know how much is required to do that.. Maybe soneone else with toss a bone
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
Flip the pitman arm? I read multiple places that people were saying that I don't need to change control arms, pitman Arma or track bar with a spacer and new stock coil..?
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
I already bought the sway bar drop bracket so I figured I might as well as throw in on instead of trying to return it and it could potentially save my sway bar from bending with my lit
Can anyone else comment on my statement about leaving the control arms, pitman arm and track bar stock while putting a new stock coil and 2.5" spacer? Thanks!
