a pulsating shake in my front end??????
jbmobbs
murfreesboro, tennessee
well i haven"t been on in a lil bit with work, fiance, and life getting a hold on me lol but my 1996 ram 4x4 has a pulsating shake to it. its coming from the front. and idk what would cause this......i just replaced all tie rods (brand new) new sky jacker shocks (hydro 7000) and track bar and the shaking persists. any help fellas????? i got to go to kentucky in a few days cause my grandpa passed......so i am tryin go get this done asap :)
BAILEY1
St Tammany Parish, LA.
2017 RAM 2500
Dat Cummins!
The pulsating shake happens when you are driving or when you are slowing down and applying the brakes?
Is your rig equipped with a steering stabilizer?
jbmobbs
jbmobbs
It happenes when im driving (no brakes) and yes it has a rancho dual steering stabilizer.
jbmobbs
jbmobbs
Any other inputs......all info is welcome. Please I really need to figure this out ...
92greenlx
Does it get worse when applying the brakes? Could be warped rotors.
Sent from my SCH-I605 using Tapatalk 4 Beta
jbmobbs
jbmobbs
No only happens when I'm driving. Its mostly between 30 and 50 mph it completely disappears around 85 mph
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Sounds like wheel hub/ bearings to me. Jack up the truck see if you can wiggle the tire and rim with a hand at 12 and 6 if there is wiggle you have found problem.
$miley
Birddog
West Palm Beach, FL
2016 Bright White 3500 Laramie 4X4 Long Bed
6.7 Cummins TD, 3.73
A friend of mind had a cracked rotor or wheel mount on one side that caused a lot of shaking once. I forget which one but he said the mechanic said he sees it all the time on rams.
There are actually videos on YouTube about rams shaking violently in the front end. I think they've nick named it the death shake. It's particular to rams not any other brand. I'll see if I can find one of those videos and post it.
Sent from my SGH-T999 using Tapatalk 2
Birddog
West Palm Beach, FL
Sorry I was wrong... They are calling it the death Wobble. Watch this video and see if this is what your truck does.
https://www.you 2500 tube.com/watch?v=FchRc5B0W6A&feature=youtube_gdata_player
There is also a video of how someone cured the problem with a steering stabilizer. I think someone mentioned that in another post above.
https://www.youtube.com/watch?v=j7LeZTpBQuM&feature=youtube_gdata_player
jbmobbs
jbmobbs
Death wobble is caused by a bad track bar........I replaced rotors last night. Still shakes. Bearings are fine. I rotated wheels and it still comes from the same location.
95Twenty500
95 dodge 2500 single cab long bed 4wd 5spd
5.9l v8
Hi Ive been reading alot on here, but have just now made an account. Something that could be causing your vibration could be your front u-joints, I am not positive just an idea worth checking out. Good luck!
