Deaconsfan
The abs and brake light have been on in my ‘04 Ram w/5.7. I just haven’t had a chance to look into it yet. The trucks been driving fine and I haven’t had the erratic speedometer that others had mentioned with the speed sensor issues.
Started the truck up today, and when I pressed the brake to put it into to gear the engine stalled and shut off. The speedometer also slowly moved around gauge, topped out, and then came back down. I tried multiple times to put the truck in gear, with the same result.
I disconnected and reconnected the battery ground, since that was the only thing I messed with since last driving the truck. Afterwards I was able to put it into gear just fine.
Was that just dumb luck, or would the battery connection actually cause that (the connection wasn’t loose)? Also, would this be a speed sensor issue, I would think the truck would have to be moving for that to play a role and cause the engine to stall out?
