- Joined
- Jan 17, 2016
- Posts
- 23,652
- Reaction score
- 54,311
- Ram Year
- 14 Sport
- Engine
- 5.7
@RoadBoss2 Marc this is a picture of a 2011 diff under my 2014. If you look close you can see where they moved the ABS sensor from the front of the diff to the rear of the diff in 2013. I had to grind a small notch in the axle flange to be able to use my 2014 backing plates and brakes,you'll have to do the same except on the front of the diff to reuse your 2011 backing plates and brakes.It's a good time to clean up and lubricate all the moving components in the emergancy brake set-up,as they're easy to get at when you remove the axles to install your 2011 backing plates and brakes.
This is the truck the diffs are from,front diff has a little over 12,000 clics on it,the rear diff has about 30 clics on it ,after it was rebuilt under warrenty.Dodges limited slip units don't like water box burnouts and drag radials,lol
