ABS Traction Control lights
Lymanjj
Lexington SC
Had a flat left front on my 2016 Laramie 4x4. Repaired flat and reinstalled wheel now the ABS/ Traction Control lights are on. Any ideas?
Fast69Mopar
The first thing I would do is inspect the ABS Sensor and wiring at the left front hub bearing and make sure nothing is damaged. If you do not see any visible damage to the sensor or wiring harness then you will need to get a quality scan tool hooked up to see which DTC's are set in the ABS Module and go from there.
A scan tool from your local auto parts store is not going to do the job. If you have a shop that you have a relationship with or feel comfortable using then I would take the truck to them.
JohnnyMac
SouthWest Washington
2018 1500 Laramie / 2024 3500 MegaCab Laramie
3.0 EcoBurner / 6.7 Cummins HO
Like @Fast69Mopar said, I put my money on the sensor in the tire being damaged when the tire lost air. Especially if you drove on it for any distance. Good luck and let us know what you find please.
