abs traction control service 4x4 light on
Dutra
bay area
Yes, already checked. This is a known issue on Rams. Lots of articles on this online
Johnnyroastbeef
PA
Cummins
SO i brought the truck to my mechanic and brought him Genuine MOPAR parts, both front wheel speed sensor AND ABS Module. He installed both and said once he put in the new ABS Module it set off every code in the entire truck! He told me he researched everything he could and couldn't get the codes cleared. He said either it's the wrong part, or it requires dealer programming. He put the old ABS Module back in and all the codes went away.
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
You have to do an ABS Initialization. Can be performed with AlphaOBD or advanced scan tool.
The mechanic should know this.
Johnnyroastbeef
PA
Cummins
he said the module wouldn't let him in to do the initialization. any advice?
I'm assuming it's his scan tool but who knows.
sounds like my next move is bite the bullet and take it to the dealer.
ReiTumber
Utah
I have this issue on my ‘09 ram 1500. I know it isn’t the brake sensor as it happens randomly as I am driving. I had it scanned and it gives codes for the passenger side rear wheel speed sensor. I replaced that and the connector and it is still occurring. What else can I try without throwing money at it hoping for a fix?
ReiTumber
Utah
Found the issue…. I went and had the dealer test everything and they said it wasn’t the abs module or pump. They said it was something with the right rear tire. I got under the truck and followed the cable back and I noticed that the connectors holding it to the chassis had broken and the cable was laying across the exhaust pipe. I hooked it back up and the issue has been gone since
Johnnyroastbeef
PA
Cummins
So update on this issue, I had the right front wheel speed sensor replaced. it fixed the issue...BUT I understand a lot of posts suggest it's not actually a permanent fix and the issue will return. it's been a few months and it has not returned yet. I'll update my post if/when all the lights come back on.
J
joshysock
ohio
U1418 implausible wheel distance signal received; I do not have power coming from each speed sensor connecter.
