Accessory Lights
davesue4b
Illinois
Where can tap into a power source for grill lighting? I could not find a source in the fuse box. I only want the lights on when engine us on. 2022 power Wagon 6.4 liter. Thanks, Dave
GeauxinUp
Navy Badge
Louisiana
2026 Limited
3.0L TT H.O.
What do you mean by "could not find a source in the fuse box"?
D
davesue4b
Illinois
All spare fuse locations did not have the fittings to hold a fuse or provide 12VDC. I would have liked to install a fuse in a spare fuse location to protect the circuit. All fuse locations had a fuse in place. There is no access point that I could find to connect the grill lights.
joelmic
stl mo
2022 Ram 1500 Big Horn 4dr Quad Cab 4WD SB
GO HERE
There are PLENTY of "B" fuses to tap into in the Internal fuse box and a few spare empty ones... it takes MICRO fuses but I have already successfully taped one for one of my projects...
"B" meaning "A" is battery, "B" is ignition ... if you need further help let me know
I show how here.... https://www.ramforum.com/threads/added-a-second-cig-outlet-off-dash-outlet-fuse.222049/
I also asked your exact same Question here:
joelmic
stl mo
I'm just hoping the OP saw this by now ????
No members online now.
Doug70767
