pgr1990
- Jun 24, 2016
- 490
- 352
- 2015
- 3.0 EcoDiesel
I enabled DRLs on my Recon headlights. Im probably the first to do it on a 4th gen w projectors.
A LOT of trial and error because the RECONS don't even have a DRL pin to connect to the oem harness so basically I used the DRL 1 module and followed the instructions on this thread: http://www.ramforum.com/f75/installing_drl_module_amber_leds_full_power-82702/
The only difference is you connect the DRL wires to the parking light PIN 2 instead of the DRL pin 4 on the oem harness because the recons don't have a Pin 4. You do not use the Blue parking light wire from the DRL 1 module at all. I had the DRL and Parking light wires from the module connected to the OEM parking light wires and it wasnt working. Once I disconnected the blue parking light wire they worked perfectly.
Here's a photo with the DRL's
