I did it, Piece of cake. I bought the OEM set-up (02-08), comes with a big Paper Map type template and complete wiring set-up for $85.00. You could start there and just get the Recon smoked after, or patiently paint your assemblys with VHT ahead of time. The (Holes) Trick is to use a white colour coded saw hole Bit made for metal. Nice clean cuts with cordless drill and with the overall design I have no leaks. I found the plastic roof plugs for the Stainless screws a bit tricky as you have to hold them inside with one hand while torqing the final gap as it spun a bit. The headliner does not have to come out completely, just undo around the door jams to the rear/center post and the overhead thingy in the middle. Hardest part there is accessing the screws in the visors as there is a Trick to opening up access on the plastic clip on part of the visor.
Rubberfrog did a video (under frogaliscus something like that). Start there, and I'm sure our Factory Mopar Vendor can set you up, if needed!
I have to recheck my wiring hook-up as they and my side step lights go out when Highbeam is depressed!
